Discovery 1 1999 - brake bleed requirements
Old Nov 10, 2020 | 03:31 AM
archaeology_student's Avatar
Default Discovery 1 1999 - brake bleed requirements
Just a simple question regarding a brake bleed on a Discovery 1 (‘99 was a transition year to Disco 2, but this is a series 1).
Is it roughly as simple as cracking the bleed valves, draining the fluid and replacing the fluid and that is it?
Since it has ABS does it require using a scanner tool as well to purge the system or is it a Simple fluid replacement?
Thank you for your help
Old Nov 10, 2020 | 08:01 AM
Best4x4's Avatar
Crack the bleeders & go for it. I've never had an issue with bleeding a D1 or having to power bleed it.
Old Nov 10, 2020 | 02:00 PM
WaltNYC's Avatar
1. rear passenger
2. rear driver
3. front passenger
4. front driver side
Old Nov 12, 2020 | 12:36 AM
jimvw57's Avatar
I had a lot of trouble with my 97, ended up using a hand vacuum pump that worked great! and you could do it with one person.
Old Nov 13, 2020 | 09:59 AM
fishEH's Avatar
I use a Motive Pressure Bleeder with a Power Probe master cylinder adapter. Well worth the money IMO.
MPDano
Jun 29, 2015 08:12 AM
sharp
Feb 7, 2009 10:00 AM
sdsilvere38
Sep 2, 2008 09:35 AM
KeizerRover
Mar 15, 2008 01:24 PM
flyingalexf68
May 9, 2006 01:51 PM
