Engine ticking
Looking to get some advice. Sounds like tappets or ??
It is only on the passenger side. Sounds like it is towards the back of the engine.
1995 discovery engine noise - YouTube
Would do an oil PSI test cold and hot, idle and 2500 rpm and post numbers. Would not drive truck. Would look at https://landroverforums.com/forum/di...-repair-37551/ and https://landroverforums.com/forum/di...estions-46975/ for low loss filter. If running 10W30, switch to 15W40 Shell Rotella. Maybe as part of the procees a quick oil flush product. You can also listen along the valve cover with a stick or long screw driver touched to ear and cover, should be able to localize sound.
I do not have the tool to do a oil pressure test. I have already put on the high capacity oil filter and installed rotella 15w40 oil, I have also added the Lucas oil additive. Does anyone in Colorado have the oil pressure tool?
Last summer I did the head gaskets including all the exhaust gaskets. I did find my exhaust bolts a tad loose but not enough to give off a false tick sound. They have since been torqued. 3 weeks ago I did the downpipe exhaust gaskets in hopes that was the noise. After that had no effect I stethoscoped the passenger head and the closer i got to the rear the louder it got.
I used it on mine. The adapter in the kit that fits the port on the disco is a teensy bit too small. However getting it nice and snug, but not over tight, everything worked ok.
