Fast Idle problem driving me crazy!
Old Oct 2, 2013 | 01:13 PM
  #41
Mattvail's Avatar
I am having a similar issue. I just cleaned out my throttle body and cleaned my MAF and adjusted my idle. (Disco 97)it now idles great just below 800ish. However when in park it jumps to 2000. I will try the unplug and shut down.
Any pictures of the location of the coolant sensor would be much appreciated.
Originally Posted by jacekk
OK Here's the thing, I called my Rover indie Ian Campbell- great guy ex Range Rover Service manager in Los Angeles, described the symptoms - he said that at 2,000 RPM there is no way an ECU reset will solve that, too big a leap, something else is going on. So on further discussion bought a Coolant Temp Sensor.
Started the disco to move it to the garage, idled @2000 as usual, put the sensor in, she idled beautifully at 700 ran it for 15 minutes till the thermostat opened - fantastic!
Stopped the engine and went to fetch my wallet to go fill up with gas, started her and back to 2000 on restart. WTF??? Nothing I do will bring that idle down. Any other suggestions? Anyone? Because the way I feel now, either she or I are going down.
Old Oct 2, 2013 | 04:24 PM
  #42
On the 97 find the upper radiator hose. Foillow to engine. To your right are two sensors standing tall from the intake. The one with square top is monitored by the ECU. The one with a single wire is the one that drives the heat gauge. On my scanner, if the square one is unplugged I show -40F for coolant temp.
When I first got "Frankensein" (brought to life with parts froim the dead ones) it did the 2000 rpm idle. Only way I fixed it was to swap ECU and IACV from a donor truck (which can have other issues). It could be that the ECU needs to have adptive values reset. These are stored memory setting that adjust to minor changes in the various components. But then it doesn't know about the repairs you did.
Old Oct 3, 2013 | 12:17 PM
  #43
Mattvail's Avatar
Ok great. I will attempt that switch out. I switched out the ECU when I first bought the truck in 2004 so I'm familiar with the process. I'm changing out spark plugs this weekend. Ordered the original champions from Atlantic British yesterday along with a fuel pressure switch.
I took the truck out in traffic yesterday and it stalled at a light due to low idle. I had backed the idle down on the thread a few turns. So I'm trying to find a happy medium. Stupid question: do you recommend manually adjusting idle
Thanks for your very helpful responses also what kind of wires do you run in Frankenstein?
Old Oct 3, 2013 | 12:24 PM
  #44
Mattvail's Avatar
It is important to note that I can idle below 2000 in park but it's too low, maybe 550? So it begs the question is it the fix you recommended or if I do the swap out of the IAC and ECU will it give it a truer idle below 1000. Thanks!
Old Oct 3, 2013 | 12:39 PM
  #45
Mattvail's Avatar
PPS I am also experiencing a good amount of engine hesitation from time to time. I just had a new fuel pump from AB dropped in and changed the fuel filter so I can rule those out. I attempted a 2/3 seafoam last night. I put half a bottle in the gas tank (filled to ab 2/3 of gas) and put the other half in my oil crank case. I drove for about an hour and didn't experience any "white smoke" coming out of the tail pipe. I held back from "seafoaming" the vaccum hose because I don't have any experience doing that 1/3. The truck was sitting for 2 years in a storage space so I am doing my best to get it back operational. Aside from the high idle (which is a recent development due to manually adjusting the idle by hand because it was idling around 550 and stalled yesterday)and time to time engine hesitation it is running pretty well. I also did a throttle body and MAF job on it last weekend. Full disclosure
QUOTE=Savannah Buzz;423780]On the 97 find the upper radiator hose. Foillow to engine. To your right are two sensors standing tall from the intake. The one with square top is monitored by the ECU. The one with a single wire is the one that drives the heat gauge. On my scanner, if the square one is unplugged I show -40F for coolant temp.
When I first got "Frankensein" (brought to life with parts froim the dead ones) it did the 2000 rpm idle. Only way I fixed it was to swap ECU and IACV from a donor truck (which can have other issues). It could be that the ECU needs to have adptive values reset. These are stored memory setting that adjust to minor changes in the various components. But then it doesn't know about the repairs you did.[/QUOTE]
Old Oct 7, 2013 | 12:25 PM
  #46
Mattvail's Avatar
Update:
I replaced the spark plugs with champion copper that AB reccomended. I also cleaned the iac with throttle body cleaner and attempted to clean the TPS but just was able to pull the back off and nothing looked like it needed it. Also cleaned out the connection on the throttle body that holds a tube that goes from the crank case to the throttle body. It was really gummed up. Cleaned with throttle body and used q tips to remove buildup. Took my wife to work this morning and it ran pretty smoothly. No hesitation. I'm going to spare digging into the ECU for now but the next step for me includes swapping out the wires now that I've covered the plugs with STI wires and throwing in a Fram or K&N air filter.
cationmoted
Mar 10, 2012 05:25 PM
ewatk
Nov 1, 2011 03:21 PM
snowdude
Sep 12, 2008 11:05 PM
Bill E
Mar 10, 2008 01:03 PM
westernsun
May 27, 2006 04:24 PM
