Fuel level sensor wire?
Old Apr 14, 2013 | 07:25 AM
tooltech's Avatar
Question Fuel level sensor wire?
Ok guys and gals, this is the 3rd time I've had to pull the fuel pump assembly out to repair/solder the wire that connects the float arm to the rest of the assembly. I'm pretty awesome at soldering, but I suppose I'm using the wrong type of wire.
Will anyone please help advise me on the best kind of wire to use so that it flexes, bends, takes abuse and won't break off after just two weeks of wear and tear?
Old Apr 14, 2013 | 08:50 PM
tooltech's Avatar
Was this a dumb/lazy question or is there anyone out there that knows the answer? I'm too **** to just not have a working fuel gauge.
I've searched and rearranged my keywording several times, but only come up with ohm, mA, and V specs, but not the type material and gauge of wire.
I'm a tooling tech, not an electrician. Sorry.
Old Apr 15, 2013 | 01:01 AM
Stranded wire, and with the finest (smallest) gauge strands making it up. Should droop like a wet noodle when you pick it up. Some meter test leads are that way, some headphone / power supply wires for cell phones and IPods. While it is the wrong size, an example is welding cable, very hefty, but flexible. Regular copper wire of same gauge as welding cable is not very flexible.
Old Apr 15, 2013 | 04:12 AM
tooltech's Avatar
Thank you Buzz.. I was using 5 strands of the "silver" side of speaker wire. Maybe smaller gauge and more strands? I'll try that.. thanks once more!
Old Apr 15, 2013 | 07:11 AM
Exactly, smaller strands, and more of them.
Old Apr 20, 2013 | 12:58 PM
tooltech's Avatar
Just an update on what I used. Solder wick. Works perfectly.
Working on a write-up on it...
Old Apr 20, 2013 | 11:12 PM
I would have guessed audio shielded cable braid as another choice. Anything that looks like the wire inside a relay that connects contacts to base.
Old Apr 22, 2013 | 04:02 AM
tooltech's Avatar
That was what I was looking at in the maintenance shop, but only they were wires for robots and too stiff.
Standing back there near the soldering table I noticed the wick. I thought for sure it would work. And so far, so good!
Old Dec 2, 2020 | 10:45 AM
Kapow's Avatar
3rd Gear
I've been racking my brain for the past two weeks about this. My fuel sender went out, bought an aftermarket pump/sender unit, was not happy with quality and did not install it. I figure since there is nothing wrong with my OEM unit, just the sender, why not just fix the sender? The problem I ran into is, I don't know what kind of wire I am supposed to use. I don't want to blow up my Disco. The wire looks to be a braided type material. Not even sure if its metal, seems like some kind of material really. Is this the problem being discussed on the feed?
Old Dec 2, 2020 | 11:13 PM
jimvw57's Avatar
look for a high flex grade wire. we use it on robots at work but it isn't cheap. You probably don't need much.
scottdegelman
LR4
Mar 10, 2014 09:10 AM
Michael M. Koch
Oct 15, 2012 11:35 AM
kkana
Jun 10, 2012 09:07 AM
wheelgarage
Dec 3, 2011 04:59 PM
savgre25
Feb 14, 2011 06:04 PM
