Getting to oil pump etc today... questions.
Old Apr 23, 2012 | 05:17 PM
  #21
ngarover's Avatar
You would be wise to still do an oil PSI test. What you know is that you have pressure above 7 PSI to reset the switch. How much above is known only by the Rover gods, and without an offering of wild women, dancing, big fire, roasted meat, and fire-water; who knows what evil may befall your truck......
yes I know. But it's also one of those things that even knowing at this point doesn't make a lot of difference. I already know that the front cover and oil pump gears are toast. I also know that fixing that correctly is a 500 bill on an engine that's lived a good portion of it's life already.
Sure the PO put new head gaskets on, But you look close and you start seeing a lot wrong with it, like the missing vac advance on the distrib, The miss matched spark plug wires... point is, I could have a grand wrapped up in it very quickly to do things right.
Again, I think this is a great truck to use as my builder, and the perfect candidate for the Izuzu 2.8 Diesel swap. It's rust free, and of course has that sweet R380...
My patch job should keep it running until that happens. Only need 3500 bucks... any donors? I'm actually selling off my 89 F350 7.3 Diesel to help finance its build.
Going to close this tread and start a new one for the trucks rebuilt like I did with the others.
Attached Thumbnails Getting to oil pump etc today... questions.-img_4132.jpg
Old Apr 26, 2012 | 12:48 AM
  #22
clifford's Avatar
NGARover, I've got the exact same issue with my '97. what have you found was ultimately the issue?
achapman
Jun 25, 2013 03:40 PM
06Range
May 8, 2013 09:01 PM
Antmen
Sep 12, 2012 11:11 AM
TheBelly
Nov 1, 2010 08:34 PM
beachpugx1
Aug 28, 2007 08:58 PM
