Hard Start
Old Oct 12, 2011 | 12:08 AM
calebbo's Avatar
Default Hard Start
I've got that hard start everybody has been having, so from what I read:
Basically the replace the fuel filter, if no go replace the pump, if no go finally the regulator. So why not just do all 3
Questions:
the regulator- can I just get one from autozone or is this a key component I should just "AB, BPUTAH, ROVAHFARM" it.
the pump- get that seal with it too right? I'm going to "R" that bad boy along with the seal
(ooooo i'm going to say ABR or ARB from now on haha)
Old Oct 12, 2011 | 04:37 AM
Why not psi gauge test the schrader valve on passenger side fuel rail to determine if you need all that (other than filter, which should be periodic replacement)? Could be cracked vac hose to regulator. And of course, you can have starting problems that are not fuel related....
Old Oct 12, 2011 | 08:00 AM
calebbo's Avatar
2 questions
Do I need a fuel pressure tester, fuel pump pressure tester, or a fuel injection tester?
I tried to convert this to PSI but... it's not really working out.
6. Reconnect the battery and turn the ignition to position II while observing the pressure gauge. Results Expected reading 2,39-2,672 kgf/cm2 Pressure drop-max 0.7 kgf/cm2 in one minute. If pressure is low check that filter is not blocked and pump is operating satisfactorily. Then recheck pressure. If pressure is still low renew regulator.
Old Oct 12, 2011 | 08:17 AM
that would 32 - 34 PSI, works OK at 30, but down in the 20's and you have a weak link. Filter is cheap. Internal pump only part is like $80. Regulator causes lots of other issues.
Old Oct 12, 2011 | 08:31 AM
calebbo's Avatar
So either of those testers would work?
Old Oct 12, 2011 | 09:05 AM
Doesn't take much more than a tire gauge. usually can rent/borrow at parts store. Same fitting as on a tire.
Old Oct 12, 2011 | 09:13 AM
calebbo's Avatar
Oh okay, I have one haha
Old Oct 12, 2011 | 10:54 AM
Not quite what I meant. Yes, you could use a tire gauge, but then it will have gas in it, so dispose of it. The test gauge is not too much more sophisticated than that, and they rent a kit (usually refund money when you bring back) at the parts store. Have rag around it so you don't squirt fuel on warm engine parts or we could be coming to your house for bar b que.
Old Oct 12, 2011 | 11:18 AM
calebbo's Avatar
Haha I understood, I just happen to have a few el cheapo tire gauges laying around. I'll post my results when I get to it.
Old Oct 12, 2011 | 01:19 PM
Danny Lee 97 Disco's Avatar
I did that one day and the schrader valve itself bit the dust. Fuel flowed everywhere.
Mine did not have a cap on it when I bought it. All I can figure is the valve itself weakened. I unbolted the valve body from the fuel rail, walked down the hill to a old Filling Station/Tire Dealer. They installed a new insert that matched the color code on the old one, gave me a few spares and had a good laugh about it.
I was concerned about the fuel compatability but it has held up fine.
atikovi
Mar 27, 2016 09:05 PM
snads
Dec 6, 2014 02:42 PM
armyeng
Mar 8, 2011 05:58 PM
robdis96
Jun 8, 2007 05:28 PM
lynn
Jul 3, 2006 01:09 AM
