Hard Start got me and my mechanic puzzled
Old Dec 18, 2012 | 07:13 AM
  #41
Perhaps - the ECU is producing no codes because the sensors driving it are off the edge of the envelope. A data reading scanner might point to something like TPS% way off, or engine coolant sensor telling truck it is way too cold or way too hot. Other than the CKP and the MAF, you should be able to unplug a sensor and the truck run using a built in fall back value. The VSS is certainly one thing to try.
Old Dec 18, 2012 | 07:34 AM
  #42
Originally Posted by Jull
ArmyRover, when I shut it off, it cleared the issue. This makes me think it should be an electronics issue rather than mechanical.
It takes 30 min to check both it never hurts to know what the internals are up to. My old carb'd 3.5 in the 110 would do the exact same thing. Cam lobes were in bad shape, the vacuum check confirmed that, and the compression backed up other internal issues.
Old Sep 8, 2013 | 08:54 AM
  #43
Jull's Avatar
I'll just revive this old thread because I hate starting new threads. Long story short, my truck stayed parked for quite a long time. Student budget and lack of time kept me from working on it.
I just got a brand new VSS and the little shaft has some play in it. I'd like to know if this is normal or I have to return the part.
Old Sep 9, 2013 | 07:00 AM
  #44
gprtech's Avatar
It's normal.
snads
Dec 6, 2014 02:42 PM
bigr1122
Jul 10, 2013 06:41 PM
glassman66
Jul 7, 2012 03:10 PM
lipadj46
Sep 12, 2009 07:31 AM
mac25dm
Aug 2, 2007 09:17 PM
