Headlamp Bulb Type
Old Nov 29, 2012 | 02:41 AM
  #31
Henrici's Avatar
Driving over the speed limit IS illegal, driving under is not
Driving with non DOT headlights/bulbs IS illegal, driving with DOT headlights/bulbs is not
Running red lights IS illegal, stopping is not (Congrats for trying to justify it tho haha)
FOR GOOD REASON!
If you cant see with properly working and adjusted headlights your vision IS the problem and you need to have it checked out, bottom line. Putting others at risk then writing about it on a public forum, you better expect to have some more responsible member call you out. I drive motorcycles and being temporarily blinded is not a laughing matter and I really appreciate the members stepping up to say so!!
my 2 cents... Happy Holidays all
Old Nov 29, 2012 | 07:25 AM
  #32
antichrist's Avatar
Originally Posted by rallyemax
And the same principle applies to pretty much all other "sacred" traffic rules.
Unfortunately your logic is faulty. You're comparing apples and oranges.
Speeding - Yeah, even though illegal exceeding the speed limit when in heavy traffic so that you are going with the flow can be safer in general since you're less likely to give crummy drivers an excuse to cut in and out of traffic.
Red lights - yeah, even though illegal, I've gone through red lights when they are stuck and there's no on-coming traffic.
The difference between these two scenarios and HID's is that in the above two you have control of when you do it, with HID's you can't switch back and forth on the fly between legal and illegal/dangerous lighting. If you could, and use HID's only on roads empty of other traffic, and legal lighting when other cars are present, then I wouldn't care if people used them.
Old Nov 29, 2012 | 08:59 AM
  #33
Racer X's Avatar
FOR GOOD REASON!
I partially agree on this point. I would say that the ECE/ e-code beam pattern is far superior to the DOT beam pattern, and I'm patiently waiting for the day where the NHSTA realizes this too and mandates the change.
Old Nov 29, 2012 | 02:35 PM
  #34
Henrici's Avatar
Those kits do look nicer than other options I've seen. Due to the poor charging systems and weak headlights on the enduros I have I did look into installing a HID kit on them. After a lot of reading I found it's far better solution to just buy quality bulbs (and what a difference!). I'd recommend anybody thinking of putting in HIDs to do what antichrist said before and get a good set of new bulbs first. Headlights are like and any other bulb, as they age their output decreases. Strictly from a practicality stand point what happens when your ballast burns out? You can't easily (or at least inexpensively) walk into any auto parts store and replace it. Save the HIDs for your off-road lighting.
sjfarbs
Jan 2, 2014 08:57 AM
darrang1
Feb 10, 2013 11:46 AM
s10lowrider1994
Dec 28, 2011 01:57 PM
Classklown90
Aug 21, 2010 07:24 PM
drdabbles
Aug 17, 2010 07:37 PM
