high idle and the IACV
Old May 12, 2013 | 03:43 PM
bushpilot's Avatar
Default high idle and the IACV
Hi all - Just changed the master cylinder and bled the brakes on my D1. Its such a nice day that i thought id work on my high idle issue as well. I've read many a post concerning this subject and think i have a pretty good understanding. Its either a doner IACV and ECU or a trip to a indy for a hour shop time for the testbook reset. What about if you unplug the IACV in park and the idle never changes or stumbles. Does that point to a bad iadle valve? I dont mind a trip to a garage but would hate to find out then that the IACV is no good. Just curious how I can be sure its working before i call it bad. Thanks,
Keith
Old May 12, 2013 | 07:56 PM
You should be able to have the IACV out, plugged in, and turn key on and should be able to see it move.
Old May 12, 2013 | 08:20 PM
bushpilot's Avatar
thanks Savannah. So if its out and it doesnt budge with the key on, the idle doesnt change plugged in or not plugged in its a safe bet the IACV is dead? If so and I change it with a new one is it possible the ECU will recognize the new one and bring the idle down to a normal level?
Old May 12, 2013 | 09:44 PM
XCELLER8's Avatar
fwiw.... I replaced mine with a crossover part from NAPA.....was a gm application...with the initial start up the idle was high (1800 or so )....the instructions with the new part said to drive the vehicle for a few miles at 40 mph and it should correctly set it self....well...when I came to a stop after the drive the idle had slowed to maybe 1200....still high...I shut the engine off and sat there a few seconds, restarted the engine and miracle of miracles...idle was correct. I'm sure that anyone with all the correct diagnostics could set the idle at once.....but a lot of techs have told me since that the drive it / shut it off / keep trying it method usually works.
Old May 12, 2013 | 10:08 PM
bushpilot's Avatar
would you happen to still have that NAPA part number or remember the effectivity?
never mind - found it on the web page. does 44.00 sound right?
Old May 12, 2013 | 10:21 PM
about the right price, but mine never would re-learn. Tried all the burn a chicken and dance bacwards methods on the internet. Ended up swapping IACV and ECU from same donor vehicle. Too damn cheap to go to the dealer.
bcbp's Avatar
I bought the jeep iacv. Like this one.http://item.mobileweb.ebay.com/viewi...id=16638033854
I also needed to have the ecu reset.
wick_60010
Nov 22, 2017 04:25 AM
D2 2003
Nov 7, 2017 07:41 AM
hankwhite
Oct 24, 2013 11:25 AM
elboy0712
Dec 19, 2010 02:48 PM
Suede
Apr 28, 2010 10:07 PM
