Lower Radiator Hose Keeps Blowing
Old May 4, 2011 | 11:03 AM
ryans97discovery's Avatar
The belt is fine, can anyone tell me the proper direction of the thermostat, thinking it might be backwards.
Old May 4, 2011 | 06:39 PM
Ok, looks like the thermostat is placed right, i tried with another hose and that one blew after about 20 minutes of driving.even removed the thermostat housing to verify again that the water pump is pumping correctly and it is. So no overheat until pressurizes and ruptures the hose. Any suggestions???
Old May 4, 2011 | 07:40 PM
I have no idea, sorry.
When you get it figured out let us know.
Old May 4, 2011 | 07:50 PM
jafir's Avatar
Can you flush water through the radiator with a garden hose, without any issues? How about the engine? (you'll have to take the themostat back out).
Old Oct 5, 2013 | 09:58 PM
RichardT's Avatar
What was the outcome?.
Old Oct 6, 2013 | 09:29 AM
Yes you can flush with garden hose and rags. When done pour several gallons of distilled water thru to flush tap water.
Old Oct 6, 2013 | 10:14 AM
TOM R's Avatar
Buzz I think he wants to know what caused the problem and what the solution was
Old Oct 6, 2013 | 04:59 PM
mierze6140's Avatar
Try running the engine without the thermostat. I have a feeling yours is stuck closed.
Old Oct 7, 2013 | 03:58 PM
RichardT's Avatar
Thanks Buzz, Tom is correct, I was after the final cause and solution.
I thought as the past post was in 2011, the OP had solved the problem by now - or there is a cheap Disco on the market
Thanks,
Richard.
kenk
Jul 18, 2011 09:29 AM
dhaselhorst
May 15, 2010 08:03 PM
dapo
Apr 25, 2009 01:22 PM
racdisco
Feb 24, 2007 08:52 PM
Rcraig
Aug 4, 2005 10:11 PM
