A "MUST" Read For Anyone Doing Either a Head Gasket or Valve Train Repair
Old Jan 21, 2011 | 02:50 PM
Default A "MUST" Read For Anyone Doing Either a Head Gasket or Valve Train Repair
I had this link sent to me by DiscoBob from the LRO, this morning and it is a must read for anyone looking to open up their engine for a head gasket job, valve train noise repair and all sort of other facts.
Take the time to read this, http://www.v8engines.com/engine-4.htm#pre-load
Old Nov 12, 2011 | 05:16 PM
onewingman's Avatar
Anyone know the location of the radiator drain plug on a 2000 Disco? I seem to have found anu"unused" " sending unit"...??? bottom passenger side...I can' get a good look at it...anyways...onwe way or another, I'm draining the beast...any clues?
Thanks, clueless
PS not horribly patient/hate breaking things...
Old Nov 13, 2011 | 08:31 PM
There is no coolant drain on the radiator. There are two block drains, and you loosen a hose clamp. Attached from RAVE, a recommended free download
File Type: pdf
Old Nov 17, 2011 | 09:11 PM
This is already in the DI tech section.
Old Nov 19, 2011 | 11:16 AM
onewingman's Avatar
Thumbs up DRAINS, TRAINS and LAND ROVERS
No doubt. Additionally, there's probably mention of the bracket that attached the SAI bracket is attached to behind the intake runners...I have just been unable to open the RAVE, I can get the Overhaul open...A friend, far more computer savy than myself, printed the OVERHAUL 4.0/4.6 at work for me...she couldn't get RAVE to open either...And yes, we both understand it's a pdf and requires Adope...(intentional...)
My solution was to pull an apparently...unused sending unit...an presto-painto...what little collant was in there, ain't in there anymore...
Old Jun 21, 2012 | 12:50 AM
cjaclwill's Avatar
So when My 97 Disco I starts up I hear the bubbly water sound near the heater core. Is this usually a dead ringer for a head gasket problem? I really don't have time to spend a whole day tearing this thing apart and putting back together right now. But I don't want a 400 dollars shell of a Disco either...
Old Jun 21, 2012 | 08:53 AM
That is an indicator of a coolant leak, now you just need to find out from where.
Old Jun 21, 2012 | 09:04 AM
fishEH's Avatar
It means you have air in the system. You want to establish how the air was introduced into the cooling system. Did you recently do any work on it?
I would start by thoroughly bleeding the cooling system. If the gurgling continues to return then you need to look further into how/why/where the air is being introduced.
Old Jun 21, 2012 | 09:14 AM
Jake1996D1's Avatar
Take the time to read this, RPi Engineering - V8 Engines
I posted this like 3 months ago when people tried to debate with me about engine noises.
Old Jun 21, 2012 | 09:32 AM
slanginsanjuan's Avatar
Use the online RAVE in SAva's signature if you cant figure out the download.
bikeG976
Dec 21, 2019 05:55 AM
jycsalas
May 23, 2019 03:02 PM
hubie
Apr 5, 2012 07:12 AM
Disco Mike
May 27, 2011 09:29 AM
davidlafrance
Mar 18, 2011 02:51 PM
