My 2" Lift install experience.
#51
The steering wheel sits on a splined shaft. The idea is to pull the steering wheel off the shaft, rotate till straight, and reattach to the shaft.
saintdel (01-20-2017)
#53
^ Not hard to do either. Removing the air bag isn't going to cause it to explode in your face, not if you intelligent. Follow the Rave's removal steps. You'd be lucky if it actually deploys in a crash....... supposed to be swapped out with fresh every ten years and I'd be surprised if the SRS system is even working correctly.
#54
#55
#56
Uh no, your guess was not well thought out. The Drivers side and Passenger side even though opposite side to the UK still represent the greatest weight on the Drivers side, lesser weight on Passenger side and would be installed accordingly. It's not just the weight of the Driver either, it's the steering equipment (box, shaft, column, wheel) and pedal assembly plus servo/master cylinder and ABS modulator which I would guess to add at least 80-100lbs to the Driver's side alone.
TheWhiteRover
09-12-2014 08:57 PM
