need some advice on a buy, 1995 disco 1
Old Jan 14, 2012 | 09:43 AM
re: Not true, a top-hat can be fitted.
Yes, and I would point out that process may exceed reasonable repair costs, for guys who paid very little to start with. There have also been posts around for pinning the sleeve (perhaps this is done below the range of piston travel on the bottom, not sure if it can be done in-the-truck, and there were some posts about a practice of using a punch to crimp the edge of the sleeve to prevent movement.
I will amend this and future posts, there is no way to know if the owner is planning anything from a brief affair to a frame off restoration. You are correct, it should be mentioned.
Old Jan 14, 2012 | 10:52 PM
joking41's Avatar
thanks guys so much for everything when i get it its getting a fresh oil change with filter castrol gtx not synthetic to **** about changing oil every 2250 miles. gona sea foam the gas engine and run it threw before oil change. after that gona drop the pan and see if the pick up tube is still okay and any signs of slipped liner and or bearing movement to spec other then that a good flush on the rad maybe a upgrade. tranny and tranfer case seem solid as all hell!! keep the posts and comments coming please i really do appreiciate them
Old Jan 15, 2012 | 07:51 AM
Jake1996D1's Avatar
Why not run rotella 15w-40?
Old Jan 15, 2012 | 09:10 AM
While doing all that maybe throw in a manual pressure test for the oil pump. If pan off be sure oil pickup is firmly mounted, in addition to clean. If you decide to do lower bearings in the truck, owner pedronz had a good write up posted on it.
As to oil, shoot for 40 as the last number, not 10W30, etc. And you can use standard filters, expensive filters, or a WIX jumbo 51459 filter that adds almost another quart of oil capacity. Draw back is micron rating, which is 25 - 30, but a human hair is like 80 microns. The best oil is changed frequently. Expensive oil left until next year is not a good idea. The diesel rated oils are designed for more cleaning and to keep soot (gunk) in suspension so the filter can grab it.
There are few topics that draws more opinions that brand of oil, which is understandable since most of us lean toward gear head. Too bad previous owners didn't keep up with the changes, they'd probably still be driving their Rover.
Old Jan 15, 2012 | 10:21 AM
And if oil pan is off, there is an O ring behind the pickup mount. Some use loctite on the bolts to be darn sure they don't drop the pickup into the pan while throwing gravel 30 miles from the last paved road....
File Type: pdf
Old Jan 15, 2012 | 12:41 PM
joking41's Avatar
I'm definitly gona do oil psi volts and water temp along with everything else I said. Let's see ima get new tires this summer some bf all terrains look good on these trucks might take the running boards off and sell message me if ur intrested other then that do a little cosmetic and interior work. Any more comments are lovely I thank u guys so much for everything!
Old Jan 15, 2012 | 01:13 PM
Might want to check the oil PSI before taking off the oil pan, in case pressure is so low that you need to look at bearings, which there have been write ups on for doing while in the truck.
SDRover
May 23, 2011 05:55 PM
motherman
Oct 5, 2009 06:35 PM
StormTroopa
Aug 9, 2009 05:26 PM
jwood700
Dec 23, 2007 10:40 AM
BlazinBWF
Sep 30, 2006 09:51 PM
