New aftermarket trans cooler?
So, as stated- I need to replace my leakey trans cooler in front of the radiator. I am looking at some of the smaller units at Summit Racing. They are not straight through like the original brush in there but I don't think the plumbing will be an issue. Has anyone done a similar swap? A small aftermarket cooler can be as low as $27 plus lines and clamps. Seems like a no brainer. Anyone? Thanks in advance-
You may be running at pressure that small hose clamp units won't handle. Your tranny has fluid going thru that "towel bar" and thru the driver's side of the radiator. The passenger side of the radiator is the oil cooler. I thought some one posted about it being like 100 - 150 PSI. If the clamps and hose are rated for it, great, if not, might just decide to pop off and pump ATF out at a very rapid rate.
Another option might be a parts guy or a salvage yard. Used, but still OEM.
Thanks Spike, I had heard these can spike really high at times but I cant imagine that it would be for more than only a second or two. Will be using a rated hose and clamps though for safe measure. Good luck
bcolins
Aug 13, 2013 06:41 PM
The People Family
Aug 6, 2008 10:32 PM
