Ops I got no plastic Oil Separator in the breather tube
#21
Disco96 there is a built in baffle on each valve cover internally. Yeah Toran I was tired of always finding Bosch D2/P38's with clogged OEM baffles, or engines seeping from every single place. I looked into doing just a standard type FV237 type PCV for the Bosch setup, but after I researched it I found a solution that worked in the proper direction and which was 100% bolt on and it replaced the brittle OEM baffle and OEM nipple at the intake with 1 part. I've installed a lot and I made it a Sticky in the D2 section. Lots of people have installed the FV308 style PCV and it works perfectly.
It should work out the same way with the GEMS setup. Only difference is it's mounted in between the breather lines vs directly on the intake. Flow and function will be the same so win win!
Toran (08-18-2020)
#22
#23
#25
#26
#27
Toran (08-26-2020)
#28
#29
