P1179 Error on 1997 Land Rover Disco
It looks like this P1179 code is gone again. CEL turned off on its own. Im gonna run it in today and get the smog (hopefully). The fact that this code has turned on off on off again, does that point anyone here to a likely cause for the next time it comes on? Ill still hook it up and see if i can get 02 readings just for fun through
When I went to check the readiness this AM, the CEL was still off but the codes P1177(new) and 1179 are still reporting on the OBD. I wasnt aware the the CEL could be off if there are errors reported. anyway, I read some folks had luck with a new fuel pumps to clear these codes, but I just checked the records and it was replaced along with the fuel filter in 2015 (but only 10k miles ago), so I think Ill skip that. Not sure where to go from here
