Popping Noise from Steering Box - Low Speed Only
Old Jun 9, 2019 | 12:52 PM
_ExpeditionMan's Avatar
Thanks for all the comments guys. Definitely one of my bigger forehead slapping moments.. just need to have the wife replicate the problem while I'm under there to confirm the panhard bar bushings. Hopefully that is all it is! Will also check out the steering shaft ujoints.
Old Nov 15, 2020 | 03:19 AM
95lwb's Avatar
ExpeditionMan, did you ever confirm what the issue was? I have what sounds like the same thing you had going on. I replaced the panhard rod and bushings last year so they should be good but haven’t checked yet. I also recently put a used steering box in so I assumed that was the problem
Old Nov 15, 2020 | 08:43 AM
Yup! ThIs was the panhard rod bushings. Had them replaced and the problem went away.
Old Nov 15, 2020 | 09:29 AM
disco96sd's Avatar
this was an excellent post guys - thanks
Old Nov 15, 2020 | 03:08 PM
95lwb's Avatar
Well I’m glad I found this thread to point me in the right direction, thanks everyone! My panhard rod bushings are still good, but the adjuster nut on the rod itself wasn’t tightened down all the way which caused the play and associated popping noise. I feel like an idiot for not catching it, especially because I was about to swap in another ps box since I was convinced that’s where the noise was coming from.
Fallstaff
Jul 23, 2016 06:34 PM
Externet
Dec 2, 2014 12:08 PM
98HSE46
16
Feb 26, 2013 04:03 PM
jeff spahn
Apr 15, 2012 02:03 PM
EstorilM
Mar 2, 2011 04:48 PM
