power steering fluid type
Old Feb 26, 2015 | 10:16 AM
TOM R's Avatar
Default power steering fluid type
what is a good store bought ps fluid for the d1?
Old Feb 26, 2015 | 10:42 AM
OverRover's Avatar
Castrol ATF Transmax Dex/Merc Multi Vehicle #06820 at Advance or any auto parts place. And if you must use an additive (leaks, noises) Lucas Transmission Fix #10009, not the PS stop leak.
Old Feb 26, 2015 | 11:25 AM
TOM R's Avatar
so same as transmission, think I use Valvoline atf+4 in trans and have some here
Old Feb 26, 2015 | 11:31 AM
MM3846's Avatar
I use full syn ATF. Seems to be fine.
Old Feb 26, 2015 | 11:32 AM
OverRover's Avatar
Yes, 100% same fluid as in AT. Standard PS fluid will kill the pump. A lesson you only have to learn once as a young lad.
ATF+4 should be fine, I just don't run synthetic so I can't tell you for sure.
Old Feb 26, 2015 | 11:43 AM
jafir's Avatar
Isn't ATF+4 specific to Chrysler/Mitsubishi?
Old Feb 26, 2015 | 11:51 AM
TOM R's Avatar
idk, works fine in rover trans so I must have seen it listed somewhere
Old Feb 26, 2015 | 06:07 PM
boyrover's Avatar
I have been using Redline D4 in the auto trans and in the power steering. It has been working well for the last 10K miles.
Old Feb 28, 2015 | 04:35 PM
swak6287's Avatar
Do you have to flush out the whole system, or just suck out whatever that is in the reservoir?
aftermath431
Dec 24, 2014 04:25 PM
MONEYMIKE
Dec 13, 2013 01:14 PM
drdabbles
Aug 17, 2010 07:37 PM
jycsalas
Apr 17, 2009 02:21 AM
Phototone
Mar 29, 2008 05:30 PM
