Radio, seats, & cigarette lighter not working
Old Mar 9, 2013 | 08:41 PM
  #21
The Rave electrical manual (for a 97, you did not specify) shows radio is F6 (Sat fuse panel 2) and F3 (main fuse panel); both under dash. Page 155 of 591 (radio - NAS).
Page 281 of 591 shows Main fuse (bolt in) 3 under hood and F6 under dash for electric seats.
Old Mar 10, 2013 | 11:48 AM
  #22
firstgeer's Avatar
All those fuses appear good. For good measure I check all the fuses in both boxes and exchanged the target fuses.
I tried to test the sockets with a volt meter. In the box under the hood, I got 12v from everything. I tested by putting the negative on the battery's negative. The small fuses only gave me 12v on one side of the socket and on the large ones I got 12v from the screws on both sides of the fuse.
Under the dash grounding against the body didn't seem to work as I got no volts when the truck was on or off from any fuse socket. Not sure what I am doing wrong here.
Old Mar 10, 2013 | 09:32 PM
  #23
Your ground used when metering under dash was not good.
Old Mar 11, 2013 | 06:29 PM
  #24
firstgeer's Avatar
F3 (main fuse panel) is not getting power.
F6 (Sat fuse panel 2) is getting 12v
I assume I need to see what is between F3 and the battery that could be the problem?
Old Mar 12, 2013 | 07:28 PM
  #25
firstgeer's Avatar
I'd love any suggests in where to look next. I am lost with this electrical problem.
Thank you!
Old Mar 12, 2013 | 07:44 PM
  #26
F3 is connected to the K174 accessory relay.
Old Mar 12, 2013 | 08:20 PM
  #27
firstgeer's Avatar
Thank you.
Is that one in the passanger foot well?
I downloaded RAVE, but it isn't working on my Mac. Is it only PC compatible?
Old Mar 14, 2013 | 10:42 PM
  #28
firstgeer's Avatar
Success! swapped out the k174 relay and power is back to everything.
I have attached the page that shows the location of K174 for anyone else that runs into this problem.
Thank you Savannah Buzz for all your help and patience!
Old Mar 15, 2013 | 12:54 AM
  #29
In my signature you will find links to the pdf sections of the RAVE so your Mac can be up to date.
Linebacker
Jun 28, 2015 09:53 PM
ferrelltodd
Dec 22, 2008 06:09 PM
jbond0076
Jul 16, 2007 09:23 AM
thisisheaven
Jul 12, 2007 01:03 AM
cowgirl1989
Jan 5, 2006 08:01 PM
