rear brake rotors
I've been chasing a rear brake squeal (front are fine) for a long time without success. I've tried....
Pads: Wagner thermoquiet semi metallic & Akebono ultra premium ceramic .... no difference
Caliper: replaced with brand new Lockhead (aka 'AP') brand
Rotors now have about 25k on them. And this has been a issue since they had 10k on them.
Light sanding with 400 grit sand paper removes the glaze and helps for a short while, but the squeal returns every time.
I've lubed all the sides of the pads and put the red goop on the back with almost no change. Everything I've tried helps a little for a short while and then they just go back to squealing.
So I'm about to replace the final part of the system, the rotors.
The rotors currently on the truck are the 'standard' rotors from BA so take that off the list.
What have you found to be good quality rotors at a decent price?
bcolins
Sep 21, 2013 12:06 PM
