rear main seal leak
http://www.defendersource.com/forum/...ad.php?t=53462
http://www.discoweb.org/forums/showt...ight=Rear+main
Well it did not appear to be leaking from the bearing cap, just the crank , my guess is if you remove that cap to do seals when you reinstall and torque it with new seals/sealant it may be slightly off compared to previous causing bearing to tight or loose so very slight you would not notice it and leading to failure
When I get a minute I will read the threads above thanks for the info guys
