rear main seal leak
Old May 12, 2014 | 11:05 PM
ihscouts's Avatar
Paul I think John would be speaking of the crucifix seals since the bearing cap would be removed to replace those. I don't think any harm is done with the crank stub seal. I was going to mention it too but life has me busy and Tom did the right thing leaving the crucifix's alone.
Old May 12, 2014 | 11:22 PM
jafir's Avatar
Originally Posted by Paul Grant
I looked on Dweb. He's been posting there lately. I couldn't find the thread. I also can't imagine why you'd need to go further into the engine than just the rear seal but the comment stuck in my mind. If I come across it again I'll post up.
There have been some posts recently that the rear main doesn't leak as often as the cross seals:
http://www.defendersource.com/forum/...ad.php?t=53462
http://www.discoweb.org/forums/showt...ight=Rear+main
Old May 13, 2014 | 07:19 AM
Paul Grant's Avatar
Jafir, I actually thought that Dweb thread was the one where John made the comment. I know it was on a fairly recent thread.
Old May 13, 2014 | 07:56 AM
TOM R's Avatar
Well it did not appear to be leaking from the bearing cap, just the crank , my guess is if you remove that cap to do seals when you reinstall and torque it with new seals/sealant it may be slightly off compared to previous causing bearing to tight or loose so very slight you would not notice it and leading to failure
When I get a minute I will read the threads above thanks for the info guys
NCguy
Jan 29, 2014 04:08 PM
outdoor7or24
May 21, 2012 08:34 AM
discoboy
Sep 15, 2011 12:00 AM
Classklown90
Aug 22, 2010 04:26 PM
Belaou
Sep 11, 2007 07:43 AM
