Rebuild CKP Wire / Connector?
Old Feb 21, 2012 | 07:54 PM
EricTyrrell's Avatar
Default Rebuild CKP Wire / Connector?
I just noticed some previously unnoticed cracks in the wiring towards the end of the CKP connector. Figure I'll just cut the last few inches off and splice in new wire. Is there a way to remove the pins without destroying the connector? Can the pins be found at an auto parts store?
Old Feb 21, 2012 | 08:05 PM
Rather than replacing the wire, with cracked insulation on the individual conductors, consider using a liquid insulation that dries to a plastic. See Liquid Electrical Tape & Spray Electrical Insulation – Plasti Dip. They carry this sort of thing in the electrical aisle at Home Depot. Once good, then wrap whole thing with a higher temp tape (also sold there). Most connectors have to be matched from same factory, there are more types and sizes of pins than pages in the RAVE.
Old Feb 21, 2012 | 08:18 PM
I fixed my cruise with Liquid Tape almost 5 yrs ago, still works.
Old Feb 21, 2012 | 08:50 PM
Higgs Boson's Avatar
NAPA sells the new pigtail end. You can just splice it back where the harness wire is good.
Old Feb 21, 2012 | 09:20 PM
Napa has two versions. See attached page. NAPA AUTO PARTS And there's alway duct tape to make a temp fix and see if you can slam the door on this gremlin.
Old Feb 21, 2012 | 10:15 PM
Thanks guys. I doctored it up real nice with liquid electrical tape, then high temp electrical, then wire loom, and finally a reflective heat shield sleeve.
Old Feb 22, 2012 | 04:30 AM
But your problem continues?
Blkstang728
Apr 16, 2015 08:14 PM
FLDiscoII
Sep 3, 2014 10:30 PM
djaaronreed
Dec 7, 2013 11:01 AM
scott510
Feb 11, 2013 08:36 AM
Travelor
Sep 18, 2012 12:15 AM
