Replacing Camshaft
Old Apr 13, 2012 | 12:24 PM
  #71
ValveCoverGasket's Avatar
glad the wood block in the crank thing worked well
also glad you found an obvious problem... nothing worse than tearing stuff down to find no distinct cause of the problem
Old Apr 13, 2012 | 12:43 PM
  #72
slanginsanjuan's Avatar
i think we're going in danny.
Old Apr 13, 2012 | 01:51 PM
  #73
ColoDisco's Avatar
Originally Posted by Danny Lee 97 Disco
How much was it and what did you think of the quality. I have seen a lot of complaints on the lack of quality of AllMakes. It would be good to get feedback on the other kits that people have used.
I put the invoice up earlier in this post. For the 95 disco it was $379 shipped to my door. It is $600 for 96 and up 4.0 plus shipping.
I did a lot of reading on lrrforums and discoweb which is where I came across D&D.
For the record mine started only when warm. Came and went randomly. Became constant after 5k miles. If you are getting the noise only when warm you are probably headed in the same direction.
Old Apr 13, 2012 | 02:34 PM
  #74
ColoDisco's Avatar
Midday update:
Secured the AC condenser to the hood with a bungee. You do not need to evacuate the system as you only need to move it up about 6 inches.
Cam removed:
Cam lobe worn down. This is the same lobe as the bad lifter.
Cleaned up the gasket surface for the timing cover and lubed and installed new cam. Used the break in lube that came with the cam and lifters. The new cam is not machined to allow the retaining plate but per the tech blog it is not necessary. My cover has the stop built into it.
Used the same break in lube on the contact surfaces of the lifters/tappets. installed accordingly.
Attached gears one at a time and set timing marks. Removed them and set them in the chain so the matching marks aligned. Slid gears and chain on.
For this afternoon continue assembly.
Old Apr 13, 2012 | 04:16 PM
  #75
ColoDisco's Avatar
So I am supposed to use VR1 oil during break in due to the zddp content, however noone states what viscosity. Any ideas?
Old Apr 13, 2012 | 05:21 PM
  #76
Banzai Jimmy's Avatar
Whatever is appropriate for the temperature. In the end, it's still just oil. A 10W would be fine.
Old Apr 13, 2012 | 05:51 PM
  #77
ColoDisco's Avatar
Except I can only find SAE 50 and 20w 50. Anyone know a place that carries a 10w?
Old Apr 13, 2012 | 08:14 PM
  #78
ColoDisco's Avatar
Not much progress this afternoon. Went looking for VR1 10w something and failed. Did manage to clean the timing cover and install the spacer, distributor drive gear and torque down the bolt. No pics of this.
Old Apr 14, 2012 | 07:42 AM
  #79
Colo...nice job...watching your progress to probably duplicate. My mechanic says the timing chain is the difficult part to get right. I see you marking stuff but you're totally replacing the chain and cogs. I'm not clear here how you do it. Also, I just did my front cover and chain so maybe my kit is cheaper.
Old Apr 14, 2012 | 10:46 AM
  #80
ColoDisco's Avatar
I loosened the crank bolt. Set it to TDC. Try to keep it there during disassembly. Only time I moved the timing again was removing the cam bolt. The cam can be moved into alignment by hand. The crank I put the securing bolt in and moved it into alignment. I did not tighten it just snugged it down. A quick jerk to the left it comes loose without moving the timing. The procedure is in the Rave.
