So what did you do to your Disco today?
Old Feb 28, 2014 | 09:39 AM
  #2481
fishEH's Avatar
Originally Posted by 96Disco_Andy
I'm switching to this filter today. Do I need to run more oil? Like 6.5 quarts instead of 6 because of the bigger filter.
I thought it was normally 7 qts, so a larger filter would mean more like 7.5 qts.
Old Feb 28, 2014 | 02:49 PM
  #2482
CUpgt's Avatar
Pretty sure 6 is normal. I usually just put around 6 in and then add until it's good on the dipstick
Old Feb 28, 2014 | 05:15 PM
  #2483
fishEH's Avatar
Don't you people have owners manuals???
Engine Sump = 6.3qts
Additional Capacity after new oil filter = .65qts
Lets just call it 7qts.
Old Feb 28, 2014 | 10:16 PM
  #2484
CUpgt's Avatar
Got my long arms on today. Also got my PSC Saginaw bracket and new pump. Need to smooth some stuff up with a grinder and paint the frame brackets as well as install an a arm Spacer. **** never ends
Old Mar 1, 2014 | 07:25 AM
  #2485
green-lantern's Avatar
Installed ebay radiator and thermostat.
Old Mar 1, 2014 | 03:31 PM
  #2486
tentoesjoe's Avatar
Just got a 96 SE7 that had only been driven 800 miles in the last two years, so i spent yesterday trying to get two years worth of field mice nesting and oil weeping out of the engine bay, then today i put what is probably the second coat of wax this thing has ever gotten. Then i replaced the belt the plugs the wires as well as all the filters to make and did the seafoam treatment. As I was finishing up all that stuff my new Hella's came in so I slapped those on and wired them up. I feel like I got a lot accomplished today and tomorrow I am going to grease the swivel joints and replace the coupling. Then hopefully I will be done for at least a week.
Old Mar 1, 2014 | 10:29 PM
  #2487
CUpgt's Avatar
Pics of the longer fully adjustable links.
Need to button up some things, paint the frame mounts, install the a arm Spacer and adjust everything to where it needs to be.
Old Mar 3, 2014 | 09:43 AM
  #2488
jimvw57's Avatar
Got the replacement front drive shaft installed!! only $100, since it has been below zero for the last few weeks, I took it in to a repair shop and had it done. They had to cut 2 bolts to get the old one out as the heads were down too far to get a wrench on them. Truck most definitely rides a lot smoother now!
Today it is -22 degrees but there is talk we may get above freezing this week!!
Old Mar 3, 2014 | 09:47 AM
  #2489
fishEH's Avatar
Interesting. Which bolts did they cut? Did they replace with grade 8 fine thread?
Old Mar 3, 2014 | 12:13 PM
  #2490
calebbo's Avatar
Went off roading with some guys from TREC it was a great time. I need to buy new plastic head lamp adjusters as I broke some on both headlamps. (Plastic piece that the metal needle clips into to hold the headlamp in place)
