So what did you do to your Disco today?
Old Apr 2, 2014 | 05:22 PM
  #2601
tentoesjoe's Avatar
Well i got my brake line in today so I changed all the brake lines on the rover then I replaced the rotors and pads as well as the front calipers and I replaced all my wheel hub bearings. Then I replaced my power steering pump.
Old Apr 2, 2014 | 06:45 PM
  #2602
TOM R's Avatar
Expensive day, good thing you did not pay labor
Old Apr 2, 2014 | 06:48 PM
  #2603
tentoesjoe's Avatar
Yeah even with just parts it was about 700. But I want to keep it forever and this kind of stuff has to get done.
Old Apr 2, 2014 | 07:07 PM
  #2604
TOM R's Avatar
Yeah I know what you mean, list gets longer all the time, knock out 1 thing 3 more pop up
Old Apr 2, 2014 | 07:31 PM
  #2605
tentoesjoe's Avatar
Yeah I want to do non essential stuff to the rig but the needs outweigh the wants.
Old Apr 2, 2014 | 07:58 PM
  #2606
fishEH's Avatar
I'm converting my AC compressor into On Board Air.
I had the AC Compressor and hoses from my parts truck so I cut off the fittings.
I cut the remaining portion of the hard lines off the fittings today. Tomorrow I'll drill and tap them for 1/4" NPT. My plan is very similar to Darkstar's first build.
One thing I needed to deal with was a tank of some sort for my Ashcroft lockers. I really didn't want a large tank because I would have to mount it either under the truck or in the cargo area and both were not ideal. I figured lots of guys run their air lockers off those tiny ARB pumps with tiny tanks so I set off to find a small tank.
Came across this on EBay. It's approximately 1/4 gallon. And it came with a regulator/filter and pressure switch.
Next step is to order fittings and 3/8" air brake line.
Old Apr 2, 2014 | 09:17 PM
  #2607
CUpgt's Avatar
Pulled the power steering pump and mounting bracket off my parts truck and am finally getting the ball rolling on the Saginaw P series pump swap. Hopefully I'll get the pully pressed on the saginaw so I can take some measurements for what size spacers I need. Going to drill new holes in the PSC saginaw jeep bracket, weld the spacers the the bracket, weld the engine hook plate on the back side of the spacers and box the open areas between the spacers with plate to add some reinforcement. I'm going to try to take a good bit of pictures so other people can replicate it if they want.
Old Apr 3, 2014 | 07:39 AM
  #2608
WaltNYC's Avatar
That is a full day of work. Have a beer!
Old Apr 3, 2014 | 08:12 AM
  #2609
jerdog53's Avatar
Drove to work in the snow!
Stupid snow!!
Old Apr 3, 2014 | 11:06 AM
  #2610
tentoesjoe's Avatar
Got my LED's for my clock as well as all my interior lighting. Installed and looking pretty sweet.
