So what did you do to your Disco today?
Old Sep 9, 2014 | 02:36 PM
  #3231
Shiftonthefly1's Avatar
Well decision has just been made for me . Shop called and said it's too far gone to repair and need recore. So aluminum it is.
Old Sep 10, 2014 | 07:20 PM
  #3232
socal1200r's Avatar
Default Codes / Thermalweld
Took my '99 D1 to a local auto parts store to get the codes read for the Check Engine Light. Codes 1179, 1187, and 1317 came up, but of course they can't tell me what they mean specifically for my truck. Looked around in here, but didn't find anything to tell me specifically what these codes are. Can anyone point me in the right direction to decipher these codes for my '99 D1?
Also, the '94 that has a blown head gasket was put on Craig's List. And I get this one reply, from someone who's apparently a distributor for some product called Thermalweld. Says if the truck can run for 15 minutes, and based on the description I put in the ad, he says he can fix it for $265. So I clicked on the website, (Head Gasket Repair | Original 2-Part Formula | Call 877-220-9944), and whaddayaknow, there's a video clip of their product being used on a Discovery, lol! Even though they have an A+ rating with the Better Business Bureau, my gut is telling me this is snake oil. Anyone have experience, either direct or indirect, with this stuff?
Old Sep 10, 2014 | 08:20 PM
  #3233
TOM R's Avatar
Just fixed my 1179, check fuel pressure
Can be MAF, o2, vacuum leak, fuel pump fuel filter, fuel pressure regulator
Mine was fuel pressure regulator
Che k my thread p1179
Old Sep 10, 2014 | 10:21 PM
  #3234
socal1200r's Avatar
Jesus, you'd think they could be a LITTLE more specific...so in order to clear the code, I'd have to screw around with EVERY one of those possible code sources, then have the codes read again to see if it's fixed? You'd think they could be a bit more specific, what with all this modern technology and all. Screw it, I'll just drive it with the light on until it starts acting up...
Old Sep 11, 2014 | 12:19 AM
  #3235
Doug18's Avatar
Well, Irok ND 285/75 are mounted up and on. First impressions, most of them balanced up good with not much weight (one has a mayan city on it). These tires are not nearly as loud as I was expecting drove up to the store and they were barely noticeable only slightly louder than road tires and significantly quieter compared to Treadwright Guard dogs. They also ride nice and they track straight. So far so good and I'm impressed.
I also finished up wiring my winch solenoid and plug socket under the drivers seat.
And I hooked up my CB radio
Im not sure if I ever posted a picture of my head unit but I did that recently too and it sounds much better.
Hooked up my extended brake lines from Lucky8
Bolted on my front and rear Terrafirma diff guards from Lucky8 although the front was missing the two M8-20 bolts it wasn't too bad since I remembered the transfer case inspection window bolts were M8-20 so I just used some of those.
Lastly I got these penguin statues from Lucky8 as well and I haven't figured where to put them.
If anyone has any tips for mounting a 285/75r16 to the stock tire carrier let me know
Edit: I was able to space it out with some washers (3 on each stud) enough so that it wouldn't grab the bumper as much now it opens and closes quite easily although, I'm pretty sure I am going to get a new strain of malaria or west nile virus now, there were a TON of mosquitos out this am.
Last edited by Doug18; Sep 11, 2014 at 05:16 AM. Reason: Stroke of genius (eureka moment)
Old Sep 11, 2014 | 07:07 AM
  #3236
Doug, I love your truck.
Old Sep 11, 2014 | 07:30 AM
  #3237
MM3846's Avatar
damn, that thing looks badass.
i replaced my panhard rod bushings for the second time.. this time with genuine LR bushings. hopefully these last more than a month. and of course i had to comment about not having any leaks a couple weeks ago. noticed a wet spot under my tcase yesterday, my inspection plate is leaking. argh.
Old Sep 11, 2014 | 07:49 AM
  #3238
fishEH's Avatar
Let me guess, some Sh*tPart or AllCrap the first go around? I did the same thing and mine are toast. Lasted about as long, too. I've got some Poly bushing from Ebay waiting to go in.
Old Sep 11, 2014 | 08:21 AM
  #3239
MM3846's Avatar
yup, britpart.
Old Sep 11, 2014 | 10:21 AM
  #3240
calebbo's Avatar
Installed my RTE diff guards. The local trailer shop did the welding and accidentally made a small hole in the rear diff. Drained the oil, welded over, filled back up. Good to go!
