So what did you do to your Disco today?
Old Apr 1, 2016 | 01:44 AM
  #3761
MrValingo's Avatar
Originally Posted by denverdisco1
When was the last time you replace the brake fluid? I had a failure after coming down Pikes Peak, water gets sucked in and when it gets hot becomes steam and only the e-brake saved an accident. replaced the bleeds because they were rusted from the water condensing. Cheap fix if you were heating up the brakes.
That's the weird part, before the soft pedal, I hadn't touched the brakes for prolly 15-20 mins. But I do suspect I sucked in water around the inner Pistons on the front left caliper. The seals on that side should have been replaced...
Old Apr 2, 2016 | 12:57 AM
  #3762
MrValingo's Avatar
Air horns. I installed two horns off a dump truck with a wolo 808 inline pump with a relay using stock horn as a trigger. It doesn't put out as much pressure as these horns would like but enough to sound like a train coming at ya
Old Apr 2, 2016 | 01:11 PM
  #3763
stillruns's Avatar
A video clip of this horn in action would be.. awesome.
Old Apr 3, 2016 | 04:29 AM
  #3764
D1driver_mgwarrior's Avatar
Default Replaced window motor
Replaced my window motor. It hasn't worked since i bought my rig last November. Took a chance on a $14 motor off Ebay. This baby works just fine. 1 down 2 to go. The rear motors are dead too.
Old Apr 3, 2016 | 05:08 AM
  #3765
I did my bumpers too. I really like the look
Old Apr 6, 2016 | 12:56 AM
  #3766
El Duce's Avatar
Did some spring cleaning, changed the plugs and wires, cleaned the throttle body and air filter. Wish I had done them earlier the motor is much smoother with better throttle response. Before the exhaust had some unburnt gas smell as well, which is gone now. Hopefully gained a few more miles to the gallon.
Old Apr 6, 2016 | 08:51 AM
  #3767
hrhoward's Avatar
Default Not Technicaly today but within the last 1500 miles....
Between 212-214 K Miles
Battery
Right side view mirror
Replaced door seals with DII seals
Several vacuum lines
Plugs
Wires
Belt
Front, Rear, T/C 80-140
Greased U-joints
Greased drive shafts
Oil & Filter
Air filter
Tie Rod ends
Steering dampener bushings
Sway Bar bushings
Front O2 sensors
Chevy Viscous Clutch
DII Mirror
Ignition switch tumblers
Exterior bulbs
Blower switch
A/C charge
Rear window rollers
Cargo door latch spring
Dash lights - wheat grain
Rear wiper switch
Wipers
Melted off hitch pin
Old Apr 6, 2016 | 09:58 AM
  #3768
MrValingo's Avatar
Old Apr 6, 2016 | 12:17 PM
  #3769
Nitrojunkie383's Avatar
Finally changed out the Panhard Bar Bushings over lunch. That was more painful that I thought it would be. Maybe it will make some improvement to my death wobble situation.
Old Apr 6, 2016 | 12:25 PM
  #3770
stillruns's Avatar
DII door sills on a DI? Can you give a little more detail on this, I am always interested in improvements. Thanks.
