SRS light on after replacing ignition switch?
Old Apr 26, 2012 | 01:01 PM
DiscoJonny's Avatar
3rd Gear
Exclamation SRS light on after replacing ignition switch?
I've recently replaced my ignition lock assembly and starter motor on my '97 Disco 1. Now that it is back together, the car works fine but the SRS light on the dash has lit up. I checked & rechecked the assembly, and all the pins, connectors and fuses are good. The only thing that I had to move that was related to the SRS system was the foam block at the base of the steering column, in order to connect the wiring system. Since there is no wires on that foam block, I can't see how I would have triggered an SRS issue.
The ignition lock assembly I got was a used unit, the only thing I can think of is that perhaps the unit was in a truck that was wrecked, and the airbags had deployed. If that's the case, there would have to be a switch of some sort in the ignition assembly itself, which seems odd to me.
I tried hooking up my buddies' scanner to the port, but as it is a LR they don't play very nicely. The only code I could get was ISO-9141-2, which from what I can gather is a general error code.
Beyond sticking a piece of electrical tape over the light, does anyone know how I can fix this?
Thanks.
Old Apr 26, 2012 | 07:30 PM
The ignition switch will not know if the truck was wrecked or not.
Lower the steering wheel all the way.
Remove the 2 phillips screws, remove the instrument cowel.
Remove the SRS bulb.
Put it back together.
Done.
Old Apr 28, 2012 | 09:35 AM
Danny Lee 97 Disco's Avatar
Aren't there some sort of contacts associated with the SRS in the Steering Wheel or that area?
Old Apr 28, 2012 | 09:37 AM
DiscoJonny's Avatar
3rd Gear
Is this a nicer version of tape-over-the-light, or does unscrewing the bulb and putting it back together somehow reset the system?
Old Apr 28, 2012 | 09:46 AM
Same as tape over the light.
Old Apr 28, 2012 | 09:47 AM
priceg's Avatar
If you did this repair with the battery connected, you my have had the key on and the clock spring unplugged at the same time.
Old Apr 28, 2012 | 09:54 AM
SRS module powered from same fuse (F14) as clock. Clock on? The SRS module also connects to the OBDII port, but would need an advanced scanner to read it. You can try the old unplug battery, step on brakes (dischage capacitors in the system), leave for an hour - perhaps it may clear.
Old Apr 28, 2012 | 10:00 AM
I know so little about the airbags that I avoid screwing with them just to be on the safe side.
In some states SRS activation is a big deal. Especially if the vehicle was involved in any sort of wreck.
Old Apr 28, 2012 | 07:21 PM
DiscoJonny's Avatar
3rd Gear
Thanks! I'll try unplugging the battery and seeing if that fixes it. Otherwise maybe I'll have to get it scanned by a dealer. The clock is on, so that fuse should be ok, though I can replace it to be on the safe side.
Is there a chance that I could have messed with some wires when I put the new ignition assembly in there? Are there some contacts in that area that I should check, maybe take the whole thing apart and put it back together?
georgep
Nov 1, 2012 10:13 PM
alverez
Nov 17, 2008 10:43 PM
Willie 00D2
Oct 27, 2008 12:28 AM
mfryburg
Oct 19, 2008 10:38 AM
chrisusvi
Apr 27, 2007 01:39 PM
