Steering question?
Old Jul 23, 2011 | 01:11 AM
pimnmike's Avatar
Ok so I tried for about an hour to get that steering shaft u-joint off and no luck. I didn't want to bang on it because I don't want to mess the splines up. Any helpful tips would be much appreciated.
Old Jul 23, 2011 | 01:13 AM
pimnmike's Avatar
Sorry I forgot to add that I did loosen up both bolts on both sides. But it felt like there was locktite on it. Wouldn't budge at all.
Old Jul 23, 2011 | 08:41 AM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
Did you remove three bolts from the steering gear box? Loosen the fourth and tilt the gear box to remove the splined U-joint. You have to loosen the gear box mounting bolts to make room to wiggle off the U-joint spline. I use a large prybar. Spray the joint with PB Blaster. But the secret is loosening up the gear box. You may need to remove the steering gear box control arm to get more movement.
Old Jul 23, 2011 | 06:39 PM
pimnmike's Avatar
I wasn't aware that I had to loosen the gearbox. The rave didn't mention that. I noticed that you posted about rebuilding gearboxes. I may do that while I replace my tie rods and steering dampener, and PS hoses.
Old Jul 23, 2011 | 08:49 PM
LRD2&ME's Avatar
Yeah tricks of the trade. I can teach you to rebuild the box while it is still mounted if you want. Where is your box leaking? Instead of useing all the seals and opening up the box, you can just replace as you need them. I can guide you through it. Too easy.
Old Nov 5, 2013 | 08:13 PM
coors's Avatar
LRD2&ME, big shout out for your ingenious insight. I had sloppy steering and vibs on the highway. A slight adjustment of the backlash screw was all that was needed on this 183k mile steering box to bring it back to normal.
Great info and thanks for you're consistent contributions.
johnkbl
Sep 21, 2023 06:17 AM
JoMar
Jun 26, 2013 06:20 PM
jycsalas
Apr 17, 2009 02:21 AM
The Image
Jan 5, 2008 05:43 PM
Evian
Aug 18, 2005 11:34 PM
