Using a tow bar?
Old Jan 14, 2019 | 08:56 AM
Jadedkatie's Avatar
Default Using a tow bar?
I want to use a tow bar to tow my parts truck. Both vehicles are 1998 Disco. Do I need to remove both drive shafts? Is there a tow bar that you would recommend? Any other issues that I should know about?
Old Jan 14, 2019 | 05:11 PM
wjsj69's Avatar
I would think that you only have to put trans and case each in neutral if all 4 wheels will be on the ground. If using a dolly, the rear DS s/b removed. This is assuming you're not going a long distance.
Old Jan 14, 2019 | 07:27 PM
whiskeynipple0088's Avatar
according the the owners manual page 94 - put the transferase in neutral, trans in park- key position 1 to unlock the steering, position 2 if you need to use the indicators (with the battery disconnected)
verify this info - I make no warranty of this information.
Bryan H
May 2, 2019 02:12 PM
bballjames
Sep 5, 2014 09:59 AM
Spencerfitch
Sep 13, 2010 09:23 AM
Capt Grizz
Jul 10, 2010 10:05 AM
roverohio
Apr 13, 2009 08:40 PM
