Weird Shifting/Brake Sensor Issue
Old Jul 25, 2020 | 09:18 PM
jimvw57's Avatar
My 'new' truck is also a 1999 SD, says so on the title and on the ID plate. They made them for a bit before changing to the Discovery 2 model
Old Jul 26, 2020 | 08:06 AM
colemtd's Avatar
Ok great. Mine says 1999 on the title too but the date of.manufacture in the door jam says 7/98. So.should I be buying parts for a 1999 or 1998? Are 1998 parts interchangeable?
Old Jul 26, 2020 | 09:11 AM
ihscouts's Avatar
98 99 are same same, no diff. Not so with a 2020 Chevy Blazer which you should own. Other than the park lock feature melted bulb sockets from long ago and far away do the same until LED’s eradicated that problem. High heat and amperage caused by incandescent bulbs melt the sockets, bulb holders and warp the metal tabs of all makes, it’s not unique to Rover. 21 years is a solid run. If you can find LED equivalent bulbs they would last even longer.
Old Jul 26, 2020 | 05:53 PM
colemtd's Avatar
OK thanks my friend. I will look into that. And yes you're right 21 years and still running is nothing to sneeze at. I definitely got good use out of it..
Old Jul 26, 2020 | 07:48 PM
colemtd's Avatar
And it'll be considered a classic in another 4 years for emissions waiving purposes!! Yay!!
Old Jul 26, 2020 | 09:05 PM
ihscouts's Avatar
You had to mention sneezing....... 4 years is a long time in Rover years....... I'm absolutely sure it will go far beyond with you're TLC.
Old Aug 12, 2020 | 06:44 PM
colemtd's Avatar
Originally Posted by colemtd
LOL sounds good. I have the taillight assembly coming monday or tuesday so I will install it and see what happens.
Thanks and I'll post an update..
Hi All, I installed the tail light assembly and luckily it came with all of its own sockets. I hooked it up and it worked.but then after I finished securing it I noticed the top light that is the brake light and tail light would only illuminate when the brakes were pressed.
I took it out and re-seated the bulb in the socket and secured it again into the frane and now it seems to.be working more consistently but now I don't trust it.
It seems like the bulb isn't fitting snugly in the socket so maybe it is moving around and losing contact? Anything I can do to makr it fit more snugly?
gulfstream69xr7
Mar 27, 2017 07:10 AM
ringerso
Jun 7, 2013 08:04 PM
00&04 Disco
Aug 10, 2010 10:40 AM
marlymarl
Aug 23, 2006 03:22 PM
disco12
Feb 16, 2006 10:56 AM
