Window Regulator Bushing Repair(alternative method)
Old Apr 25, 2013 | 10:00 AM
  #31
pinkytoe69's Avatar
You don't need to mess with the lock/latch stuff at all.
- lower the window almost to the bottom till you can get to the bolts on the window rail
- remove the bolts on the rail
- pull the window up and tape to the frame
TOM R - don't rile yourself up...its really not very difficult
Old Apr 25, 2013 | 01:09 PM
  #32
TOM R's Avatar
not riled up just like to see what is being used for the repair, I have repaired my pass rear one with some (I think ford bushings) other companies bushings and the drivers front I used a good reg from a disco 2 it is nice to know what is out there as alternatives
Old Apr 25, 2013 | 02:49 PM
  #33
Shiftonthefly1's Avatar
The rears are easy. They only have one roller and one track. The fronts have two rollers and two tracks. It honestly sounds harder reading it than it is. And I just did mine.
I used a bottom of a chair I found in an Ace Hardware store. It's a studded round plastic wheel. You would normally use it to adjust the height of a desk or chair. I simply filed the thickness down a bit and drilled the old roller rivet off the regulator and bolted the wheel to it. Greased the track w white grease. Works great. All for .98.
Old Apr 25, 2013 | 03:52 PM
  #34
CUpgt's Avatar
Ill take a picture of the nylon washers tomorrow. They come 6 or 8 to a bag. I used two on each track. 3 years and still holding strong.
Old May 13, 2013 | 08:53 PM
  #35
TOM R's Avatar
well the d2 reg crapped out already so guess I a fixin the d1 I took out, pics?
Old May 13, 2013 | 09:15 PM
  #36
CUpgt's Avatar
I just so happen to have a regulator with the nylon washers on it. I also have some nylon washers in the packaging. Ill take some pics tomorrow.
Old May 14, 2013 | 10:51 AM
  #37
Andr3w's Avatar
Damn. Wish the pics from the OP were still up. Guide was great. Nylon washers still working great!
Old May 20, 2013 | 07:14 PM
  #38
TOM R's Avatar
anybody?
Old May 23, 2013 | 07:00 PM
  #39
junebug's Avatar
sorry 1st time tryin to post pix.....HOPE THIS WORKS......
Attached Thumbnails Window Regulator Bushing Repair(alternative method)-rover-repair-knives-mix-015.jpg   Window Regulator Bushing Repair(alternative method)-rover-repair-knives-mix-011.jpg   Window Regulator Bushing Repair(alternative method)-rover-repair-knives-mix-010.jpg   Window Regulator Bushing Repair(alternative method)-rover-repair-knives-mix-014.jpg
Old May 23, 2013 | 07:01 PM
  #40
junebug's Avatar
HA!!! IT WORKED!!!! WOO HOO.....ok i took a bunch of pix of whole process front and back(i think??) heheh...... lemme know if any are needed.............JUNEBUG
