Wont change Gears
Old Jun 3, 2015 | 01:23 PM
dsmeddy's Avatar
Yeah, when I am driving down the road at about 50-55mph, I am running around 3000 RPMs and rpms go up as speed increases. Not changing into any other gear. Seems like I should have another gear to go into
Hope that helps
Old Jun 4, 2015 | 01:26 PM
TOM R's Avatar
YOU SHOULD BE LOCKED DOWN IN OVERDRIVE AT THAT SPEED AND running 2k rpm (approx)
my detent cable actualy is a little limp at idle between plenum and bracket so be sure it not to tight
if seafoam or similar and trans service did not fix it either you have a stuck valve body like previously mentioned or torque converter / pumps going out imo, if it is the trans good used are cheap iirc from guys on here that part out rovers
replacing the lines is a waste of $ imo unless they are leaking, 1/2" lines are not gonna clogg unless you dump dirt into you trans , check fluid level at idle in neutral, over filled can be as bad as underfilled
Old Jun 5, 2015 | 10:09 AM
dsmeddy's Avatar
I gave in and took to the shop to diagnose.
The fluid level is correct. I am waiting to hear from the shop at this point I think if I dont have them do any repairs (unknowing what exactly there is to be done) can I take the valve block off and replace the valves? is there a replacement kit of sorts?
And the TC, what servicing can be done there as well?
TY
Old Jun 5, 2015 | 10:22 AM
dsmeddy's Avatar
ZF 4HP22E Valve Body Rebuild
I believe I may of just found how to do the valves in the tranny. Lots of work it is.
Old Jun 5, 2015 | 11:47 AM
TOM R's Avatar
if the clutches in the trans are shot , needs rebuild, if the torque converter is bad maybe get away with replacing but trans comes out so...
valve bodies stick, detent out of adjustment, can be a bad pump, clogged cooler, theres only so many things to go wrong
Old Jun 15, 2015 | 10:38 AM
swak6287's Avatar
Originally Posted by fishEH
Can you clarify this statement? You should not be running 3000 RPM @ 50mph
He did an engine swap, there is a VTEC in there.
disconic
Jun 4, 2016 02:57 AM
gustav23
Dec 15, 2011 01:12 PM
collin Barrows
Aug 28, 2011 07:13 AM
joyjimmy
Nov 6, 2008 09:15 AM
96p384.6
Sep 14, 2006 01:48 PM
