‘04 D2 Inside Rear View Mirror Replacement
Old Nov 3, 2019 | 08:59 AM
Jsivey's Avatar
Default ‘04 D2 Inside Rear View Mirror Replacement
My rear view mirror is broken and I’m trying to replace it, but I’m not seeing where the wiring connector is. I’ve removed the whole arm from the windshield bracket and the wiring runs up into the headliner but I’m hoping there’s an easier way to access it.
Any advice?
Old Nov 3, 2019 | 09:49 AM
mollusc's Avatar
from memory, the connector can be accessed if you remove the cabin light or something similar in that vicinity.
Old Nov 3, 2019 | 10:08 AM
Brandon318's Avatar
Any advice?
Crack open the plastic clamshell trim.
Old Nov 3, 2019 | 10:11 AM
Best4x4's Avatar
The mirror has a connector underneath the plastic trim on the mirror base & another one further up in the headliner. If you are swapping the mirror the exact same one = same lower plug.
Old Nov 3, 2019 | 10:34 AM
Jsivey's Avatar
If I’m understanding you correctly, the plastic arm that has the ball and socket on one end (that connects to the mirror) has a plug inside the plastic arm. This would allow me to disconnect it from there rather than going under the headliner?
I have to get the windshield replaced soon so I’m trying to figure this out and replace the mirror myself.
Thanks.
Old Nov 3, 2019 | 10:39 AM
Brandon318's Avatar
Thanks.
Yeppers. Just stick a screw driver between the seam in the plastic housing to separate it and expose it’s contents. Be careful not to pinch wires on reassembly.
archaeology_student
Jun 23, 2022 08:35 AM
RA021226
Sep 20, 2018 08:21 PM
dcarr1971
Oct 21, 2010 12:25 PM
krazzz
Oct 10, 2009 02:10 AM
goldfishy
Jan 20, 2008 03:19 PM
