03 p/s hose?
Old Dec 31, 2008 | 02:25 PM
thehulk's Avatar
Default 03 p/s hose?
one day after a fishing trip inoticed iwas leaking p/s fluid and itwas very difficult to turn. after doing some research i added the lucas ps stop leak fluid and its still leaking. I traced the leak to a hose but it seems to leak where the bigger hose meets behind the pulley. How can I access this and/or should i add some more lucas since it says to add up to two bottles? what do yall think?
Old Dec 31, 2008 | 03:30 PM
Default RE: 03 p/s hose?
Which model and mileage?
No more lucas, it is time for new hoses if that is where the leak is coming from.
Old Dec 31, 2008 | 03:53 PM
thehulk's Avatar
its an 03 disco with 80,000 miles. its leaking where the hose fits the 'male' extrusion behind a pulley. If I have to replace the hoses would ihave to order them from british atlantic or an autozone type store and how would i gain access to replace the hose?
Thanks again forall the help!
Old Dec 31, 2008 | 04:00 PM
thehulk's Avatar
one more thing, is it still okay to drive?
Old Dec 31, 2008 | 06:15 PM
If you loose too much fluid, you will burn up your pump.
Old Dec 31, 2008 | 07:08 PM
To much stop leak will clog your p/s system and burn up your pump too.
Call AutoZone and see if they have the hose, if not go to Atlantic British.
Old Jan 1, 2009 | 09:20 AM
With that mileage, I would suggest you replace all 3 hoses so you don't have to tear into it again soon for another leak.
Make sure to only use p/s fluid, not atf like the D1's used.
D2 2003
Nov 7, 2017 07:41 AM
Sam95disco
Dec 6, 2011 08:52 PM
Doss
Mar 26, 2006 06:00 PM
Rcraig
Aug 4, 2005 10:11 PM
nickvillaume
Jul 19, 2005 01:52 PM
