1997 d2 dead
Old Dec 24, 2012 | 10:11 PM
etecinc's Avatar
Default 1997 d2 dead
Drove to store, came out would not start, but solenoid clicked. Thought it was battery, jumped nothing happened. Removed battery, had it checked, totally charged. Put back in vehicle now nothing happens, will not come out of park, no lights, radio, or solenoid clicking.
Old Dec 24, 2012 | 10:40 PM
lr2001silver's Avatar
Banned
First you do not have a 97 D II no such thing.
Have you checked the inertia switch?
I would be checking your main ground as if its not connected properly you will have nothing.
Old Dec 25, 2012 | 04:14 AM
antichrist's Avatar
even with the ground not clamped there would probably be a good enough connection for low current things like dash lights and door chime.
x2 on inertia switch. Also could be be the disabler. It does goofy things sometimes. The ETM has the circuit desciptions to see what to check.
Old Dec 25, 2012 | 05:49 AM
Go look at your vehicle registration and find out what your driving and try again.
Old Dec 25, 2012 | 09:52 AM
JPSpen's Avatar
LOL !
Don't let Mike rattle you.. He's actually pretty ok...
But yes, you have a D1 if it's a 97...
Check voltage from battery to main fuse panel under hood.. Then move into the fuse boxes under the drivers knee panel... You've got to be losing it somewhere.. Gotta be a main ground or something pretty damn obvious for nothing to work...
Just put your meter on the negative battery lead and start checking positives... I'm betting you don't get far without finding the cluprit...
Jumper cables can be your friend.. Run one between the battery negative and the engine somewhere and see if it lights up...
Good Luck.
John
Old Dec 25, 2012 | 11:46 AM
Banned
Yes Merry Christmas to you! Don't turn away from the knowledgeable people here every once in awhile you will catch flak but we are all here to help. Let us know what you figure out.
Old Dec 25, 2012 | 04:55 PM
On a 97 the black wire on the battery negative runs down along the radiator to a tie in spot on the frame. Has to be clean and tight. The under hood fuse box has two cables at front. They have to be clean and tight. The battery cables have to be clean and tight. The cables on the starter have to be clean and tight.
skins
Sep 21, 2006 09:20 AM
yockman
Aug 27, 2006 02:21 AM
Len_S
Jun 28, 2005 08:23 PM
Dhwright
Jun 11, 2005 12:23 AM
parpar
Nov 5, 2004 05:14 PM
