2000 Disco oil cooler bypass.
Old Mar 11, 2021 | 07:59 PM
dtladd1993's Avatar
4th Gear
Default 2000 Disco oil cooler bypass.
One of my oil cooler lines into the rad has a pin hole in and is spraying oil everywhere. I lost a quart pretty quickly. I work out of town and need to limp the truck home. Can I bypass this systems temporarily, If so what plugs do I need to plug the lines after removing them.
Old Mar 11, 2021 | 08:07 PM
Extinct's Avatar
Yes, you can use normal oil pan plugs on the front cover
Old Mar 11, 2021 | 08:24 PM
dtladd1993's Avatar
4th Gear
So to clarify, just the oem pan plugs will work? I didn’t have much time to poke around under the hood because I was running out of daylight.
Old Mar 11, 2021 | 08:34 PM
Extinct's Avatar
No, it’s a different size than the Disco pan plug, but Auto parts store should have them.
Old Mar 12, 2021 | 06:50 PM
dswilly's Avatar
When I installed my oil pressure gauge the adaptor was used in one of the cooler ports, Detailed below. So would think a plug @ M20 P 1.5
M20 P-1.5 Male to 1/8-27 NPT Female Thread Adapter
Old Mar 12, 2021 | 07:12 PM
dtladd1993's Avatar
4th Gear
Yeah after some digging that’s that what I found, I’m gonna be able to fix it and I’ll verify that Saturday. Instilling a pressure gauge sounds interesting but that’s one more thing to be paranoid about. I’ve got enough woes being neurotic about the coolant temp.
Old Mar 13, 2021 | 11:46 AM
Harvlr's Avatar
Are you sure you can just plug those lines? Doesn’t most of the oil go through them continuously?
Old Mar 13, 2021 | 09:25 PM
mollusc's Avatar
Several years of the D2 didn't even have an oil cooler. It's on a bypass circuit.
Old Mar 13, 2021 | 10:32 PM
Discorama's Avatar
4.6 D2s came with plugged oil cooler ports from the factory. The bypass is to protect the cooler against over pressure. Without there is no bypass needed.
Old Mar 14, 2021 | 09:24 AM
dtladd1993's Avatar
4th Gear
M20 1.5 works. I picked them up at oreilys for 3.99 a piece. Make sure you get them tight and check for leaks. So far so good.
merebel
Sep 29, 2020 06:32 AM
neillr
Jul 28, 2019 12:41 AM
Richard Gallant
Sep 27, 2018 11:16 PM
archaeology_student
Aug 22, 2016 11:17 AM
atancreti
Jul 13, 2011 10:20 PM
