2000 head coolant passages...
Out thru the intake manifold and the hose port (#17 in attached drawing) is located at the front. Various models have other small ports for heaters, etc. The heads to manifold water pasages are the corners. See pix of valley pan gasket. They are known to leak because Bozo did not tighten the rear bolts, some have been reported finger tight.
aguison
11-18-2012 05:15 PM
