2001 Disco SE7 starting issues
Old 01-27-2012, 10:47 AM
BPoU has new ones for $265 or you can get one from a wrecking yard for $50 to $100 to get you by.
Let us know what you find.
Old 01-27-2012, 10:52 AM
rbwdriven's Avatar
cool I'll try and work on it tonight.
Thanks
Old 01-27-2012, 04:51 PM
rbwdriven's Avatar
so got home tonight.
try to start and nothing happens.
lights come inside.
Turn ignition on and the door chime dings
lights come on in the dash and that is about it.
Old 01-27-2012, 07:10 PM
There are several large wires in the front of the underhood fusebox. Just like the battery cables, they need to be clean and tight. Got a voltmeter?
Old 01-27-2012, 07:24 PM
rbwdriven's Avatar
Yep got lots of tools.
play with cars for a hobby.
I even have the abs amigo.
I got lots of tools.
What am I looking for?
Old 01-27-2012, 07:46 PM
Starting and charging diagram and photo attached. Big brown wire is from alternator, so amps come thru it and the 150 amp fuse link to do everything else. Red wire is cable to battery (632 in picture).
Volts to chassis at red wire should be above 12. Volts to chassis ground at brown wire should also be 12 or above.
On back of alternator, big wire is the output, should read 12 volts to chassis or motor. It goes to + battery terminal. Should also be clean and tight.
Smaller wire, which is brown/yellow, should be + volts to chassis ground when ignition is turned on, that voltage goes through the battery light and "excites" the alternator and makes it put out. If no + volts there, no output amps from alternator. Controlled by fuse 27.
File Type: pdf
File Type: pdf
File Type: pdf
Old 01-27-2012, 08:11 PM
rbwdriven's Avatar
Is the suppose to be something hooked up on c0601?
I have an opening, looks like there was something at one time.
hole, no screw or wire
Old 01-27-2012, 08:25 PM
I searched the electrical drawings for 601 and it came up as a connector to a secondary air injection pump (SAI). And obviously, if don't have 13 volts or so here (wires in fues box), battery is getting flat. So if you can jump off truck, meter readings across battery should be 13.8 volts to like 14.4. If battery is getting that kind of volts with truck running, switch on more stuff, like lights, fan, AC - volts will go down a little but not less than 13.2.
If good volts with alternator running, switch off truck. Measure battery volts. Just turn on head lights. If volts drop a whole bunch, like to 11 volts, with just that load, either loose ground or some other connection - or dead cell in battery (won't hold under load).
Old 01-28-2012, 07:41 AM
rbwdriven's Avatar
that will work.
Ok now I know that I'll start working on it.
I'm slambed with family and photography stuff today so I'll be getting to it hopefully in between all of this.
MrFlea1
01-23-2012 03:57 PM
RoverBimmerRX7
07-22-2011 09:16 PM
pedro62
02-23-2009 02:19 PM
abrim
03-04-2008 10:14 AM
lskreyn3
11-20-2006 11:06 PM
Quick Reply: 2001 Disco SE7 starting issues
