2001 disco wont start
Old May 4, 2013 | 09:27 AM
dirtlord's Avatar
Default 2001 disco wont start
2001 disco. today it started up fine, it was pretty low on gas, drove it to the gas station out gas in it, then it turned over fine just wouldnt start. left the car came back in 25 min. it started right back up fine. drove it home. then the next thing it started up fine. drove it about 3mi then it just died and wouldnt start again.
any ideas? i havnt had any other problem like this with this car. fuel issue? its raining out so i cant get out to look at it.
Old May 4, 2013 | 09:34 AM
Classic problem with CKP - crank shaft position sensor. When stopped, engine block heats the sensor just a little more. Sensor connections inside open up. Pour cold water on it to speed up return to normal. Won't get better.
Confirm with a spare spark plug - when it quits, plug in the spare and lay on manifold, crank, check for sparks. No sparks if CKP dead. Don't have CKP hold the plug while testing, that is considered bad form.
Sensor is $50 - $80. You can DIY, but some prefer to pay a shop an hour for this. The access is tight, needs long pliers, and you have to plug sensor in and let it hang to remount. Take parts off with care and put back in same order, guys mess up the spacers all the time and can't start with a new one.
Now if the spark test is OK, then look a fuel pump electrical connections under plate and carpet in the cargo area.
Old May 9, 2013 | 07:26 PM
dirtlord's Avatar
i'll give it a try thanks
disconic
Jun 4, 2016 02:57 AM
gustav23
Dec 15, 2011 01:12 PM
armyeng
Mar 8, 2011 05:58 PM
derek.saylor
Jan 30, 2011 12:50 AM
jonsimon
Jan 29, 2007 01:55 PM
