2003 disco 2, M&S lights flashing, truck will not move
So I went out to get in the truck this morning started fine but would not move, M&S lights on the dash flashing. I've searched most of the transmission threads and have not seen one where the failed XYZ switch totally disabled the vehicle, do I have a different problem or is it like to the XYZ switch also? Vehicle info: 03 disco, 160k miles. Any suggestions would be appreciated.
Yes it could be a XYZ switch , but they are $$$ to guess. I would have the charging sysyem checked. The trans. Ecu is sensitive to voltage. Iirc there is a ground issue that will cause this also. Does your tranny shift? or is it in third?
Station1
06-01-2018 01:17 PM
importdave
09-25-2014 10:18 PM
CtCold
01-23-2013 06:58 PM
