2003 disco 2, M&S lights flashing, truck will not move
Old Oct 31, 2015 | 08:30 AM
Extinct's Avatar
Default 2003 disco 2, M&S lights flashing, truck will not move
So I went out to get in the truck this morning started fine but would not move, M&S lights on the dash flashing. I've searched most of the transmission threads and have not seen one where the failed XYZ switch totally disabled the vehicle, do I have a different problem or is it like to the XYZ switch also? Vehicle info: 03 disco, 160k miles. Any suggestions would be appreciated.
Old Oct 31, 2015 | 09:54 AM
lordmorpheus's Avatar
When you move the gear shift from park to reverse and drive, do the lights on the indicator light up, or does the correct gear in the instrument cluster show?
Any recent work to the vehicle, or any recent off-roading, water crossings, etc?
Old Oct 31, 2015 | 01:46 PM
drowssap's Avatar
Yes it could be a XYZ switch , but they are $$$ to guess. I would have the charging sysyem checked. The trans. Ecu is sensitive to voltage. Iirc there is a ground issue that will cause this also. Does your tranny shift? or is it in third?
cobbcj7
Nov 17, 2014 06:01 PM
importdave
Sep 25, 2014 10:18 PM
CtCold
Jan 23, 2013 06:58 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
