2003 discovery se no heat in cab and over heating
Old Jan 10, 2013 | 03:50 PM
jfall's Avatar
yeah, I missed he did his HG's.
Well, maybe time to pressure up the coolant system and force out the leak to see where it is.
Check the belt for routing - make sure the WP is going the correct way.
Maybe replace the thermostat - just to have that done.
Old Jan 10, 2013 | 04:04 PM
Belt route first, radiator is most likely sludged up good second. Having some water flow thru radiator is possible even with lots of the tubes closed off, DIY flow testing may be problematic without test equipment. Leaks can be from any hose or clamp (in addition to gaskets); some are slightly hidden; if you have coolant loss.
It is more correct for radiator to be cooler (but not cold - that would mean all the tubes are sludged) on passenger side (NAS) as it is a horizontal row radiator. What counts is top to bottom on the fins in the same vertical line. More than 10F and you may have some blockage.
Thermostat can be sludged up with trash, the little holes in top leg must be clear for it to work properly.
Attached Thumbnails 2003 discovery se no heat in cab and over heating-sludgerad.jpg   2003 discovery se no heat in cab and over heating-land%252520rover%252520thermostat%252520005.jpg   2003 discovery se no heat in cab and over heating-dex-cool-2.jpg
Old Jan 10, 2013 | 08:02 PM
PLOWER99's Avatar
Thank you Savannah I appreciate the input. I am going to go after the radiator. I will let you guys no what happens.
SolbergFanBoi
Mar 5, 2012 07:05 PM
Havoc556
Nov 1, 2011 08:48 AM
bulldozer32
Nov 12, 2010 03:00 PM
boilerman
Nov 12, 2008 07:35 AM
djones70
16
Apr 11, 2008 12:38 PM
