2004 Disco 2 Engine Rebuild
Old Nov 16, 2019 | 04:20 PM
  #151
cvhyatt's Avatar
Default Painting The Rims
Decided to try out the rustoleum peel coat on the wheels. Turned out great on the spare so now I am on to the others!
Old Nov 16, 2019 | 05:10 PM
  #152
Discorama's Avatar
How are these tires working out? Still rubbing?
Old Nov 16, 2019 | 05:21 PM
  #153
cvhyatt's Avatar
Yeah the rub but only on tight u turns or pulling into a tight parking space. As long a I go wide when I am turning I don’t have any issues. All the same, I will probably get some spacers for them in early 2020.
This coating is pretty flawless and self leveling. Very impressed with this stuff!
Old Nov 17, 2019 | 12:05 PM
  #154
cvhyatt's Avatar
Default 11/17 Update
Finished up the wheels and added an LED bar I got as a gift.
New light bar
Finished wheels
Old Nov 17, 2019 | 05:26 PM
  #155
cvhyatt's Avatar
Default More Progress Today
I made a lot more progress on the disco today. Lots of little things but the biggest one was an intermittent chirping while in motion. Last week I greased the new front drive shaft and tried to do the rear one but the zero fitting was clogged. I finally got around to it this weekend. Pulled it off and cleaned it out with paper clip and some break cleaner. Screwed it back on and pumped the shaft with grease. Took it for a test drive and the chirp is gone!!! I thought sure this was the shocks or springs but it looks like the rear drive shaft had been neglected for some time. Also since the smoke test, tightening down a intake hose clamp and cleaning out the vacuum solenoid the SAI error codes have not returned.
Lastly I picked up some 1000 grit sand paper and lightly sanded the alacantra panels and they look new now! Can believe how easy that was!
With as much money as I have sunk into this thing it feels good to get so many nagging things behind me.
Alacantra panels look new!
LED twilight in Florida
Old Nov 18, 2019 | 11:35 AM
  #156
yardpro's Avatar
great project and documentation.
Old Nov 18, 2019 | 05:11 PM
  #157
cvhyatt's Avatar
Default Spoke too soon...
Guess I will be replacing the vacuum solenoid after all!
Old Nov 18, 2019 | 06:50 PM
  #158
Dave03S's Avatar
What was the operational symptom of that SAI valve being leaky, other than the codes?
Old Nov 18, 2019 | 07:38 PM
  #159
cvhyatt's Avatar
When I did a smoke test, all the smoke was pouring out the solenoid.
Old Nov 18, 2019 | 08:05 PM
  #160
cvhyatt's Avatar
I wonder if I have the vacuum tubes going to the solenoid reversed from when I replaced the purge valve. Would it cause an issue to swap them around and see it that resolved it before buying a new solenoid.
