2004 Disco 2 Engine Rebuild
Old Feb 20, 2020 | 05:02 AM
  #241
cvhyatt's Avatar
It has a very stout adhesive on the back. The fiberglass layer in the middle acts as a sound deadened and an air gap.
Old Feb 20, 2020 | 06:14 AM
  #242
Sixpack577's Avatar
And it's interior/exterior then?
Old Feb 20, 2020 | 06:37 AM
  #243
cvhyatt's Avatar
Typically only used for exterior. Here's a link to the actual product. It's expensive but I can't believe how effective it is. The temps of my seat rails used to be 118F Now they are 87F. I wish I could line the whole underneath of my truck with this stuff!
https://www.designengineering.com/fl...e-heat-shield/
Old Feb 20, 2020 | 06:41 AM
  #244
Extinct's Avatar
That is a huge sound decrease, each 10db is roughly half as much sound
Old Feb 20, 2020 | 06:59 AM
  #245
Sixpack577's Avatar
Thanks, I will be using this(either on this D2 or if I replace the frame or whole truck/frame has now had it)
Old Feb 20, 2020 | 07:57 AM
  #246
cvhyatt's Avatar
Yeah I was pretty blown away by it. To be fair, I was missing a big chunk of heat shield to begin with so that is probably why it is so pronounced. Not sure folks would get the same results if they were replacing existing.
Old Feb 20, 2020 | 11:28 AM
  #247
Richard Gallant's Avatar
Wow that is impressive
Old Feb 23, 2020 | 12:13 PM
  #248
cvhyatt's Avatar
Default 2/24 Update
Truck is running great! Got a few nagging issues I am still working through. I am still fighting the P0441 error which doesn’t look like it has any impact on performance but I hate the nagging yellow light. I had already replaced the purge valve and the vacuum control solenoid and performed a smoke test but the error keeps coming back after a week. I decided to add some clamps to my vacuum tubes to see if that would help. In doing so I found that the maf hose was partially off the intake so maybe that was the issue? In any case I readjusted and tightened in and installed the clamps.
I also had some leftover DEI heat shielding so I installed that around my starter and my crank position sensor.
CKP wrap
Starter wrap
Next items on my list are as follows:
  1. fix slow power steering leak
  2. fix various slow oil leaks
  3. send oil out for analysis
  4. fix curling dash
Old Feb 23, 2020 | 12:28 PM
  #249
I use zip ties on those lines, mine are pretty worn and tend to come loose with a bump. like the clamps though what size are they ?
Old Feb 23, 2020 | 12:36 PM
  #250
cvhyatt's Avatar
Yeah I read somewhere that zip ties don’t apply even pressure around the tubing and can prevent a good seal. I found these spring clips on amazon which should provide even pressure around the tubing.
WMYCONGCONG 155 PCS Spring Clips Silicone Vacuum Fuel Hose Line Water Pipe Air Tube Clamps Fasteners Assortment Kit 6mm 8mm 10mm 12mm 14mm 15mm 16mm 18mm 20mm 22mm
Amazon Amazon
