3 Amigos question
Old Oct 16, 2012 | 09:15 AM
  #21
breckasaurus's Avatar
Originally Posted by Patrick Duffy
The problem was diagnosed by the LR dealer as an Overlay Harness required. I have the correct part - basically a wheel sensor with a continuous cable running back to the ABS.
I am confused! The instructions I have tell me that I need to run the cable from the back wheel through and into the engine bay and follow the loom across the bulkhead. The plug on the ABS unit looks like the one in the photo that comes with the instructions.
I have come across another set of instructions which also look like an official LR document but it talks about running the cable to the SLABS which is under the drivers seat. The plug on this bears no resemblance to the one in any of the photos - can someone clarify please?
D2 2000 123,000 miles.
My real problem was one of my sensors. But I didnt trust their (dealer) input because as soon as I changed one, they charged me again to diagnose $135 - that the other was now failed. Coincidence or did they not even look at all the codes first time around. Its fixed now so no worries.
Old Oct 16, 2012 | 11:01 PM
  #22
Bkreutz's Avatar
The SLABS ECU is under the right side of the dash not under the drivers seat (maybe the instructions are for the UK market?), you access it by dropping the glovebox (don't need to unbolt it, just open the box, disengage the stops on both sides so you can open the box further, then just let it hang down)
Old Feb 25, 2017 | 03:02 PM
  #23
Alex Rowland's Avatar
Default Replaced all sensors
I have replaced both front hubs and the abs pump module on my disco 2 and then had to replace a few brake lines. In doing so rthe abs pump needed to be power blead and codes cleared at a dealership. They came back so I just now the rear sensors, since the hubs were good. The amigos are still on. I going to have to take it back to the dealer again???
Old Feb 25, 2017 | 03:23 PM
  #24
OffroadFrance's Avatar
Originally Posted by drowssap
it could be anyone one of a dozen things all of which you can replace and still not fix the problem, you need to have the ABS codes read and get back to the forum with the code numbers. This is an area that can get very costly if you just start guessing and replacing parts.
X1 ......... amen, and still end up chasing your tail. It's all in the codes, codes, codes and more codes. A cheapo diagnostic kit won't identify exactly the problem(s) so you need ALL the codes professionally read and cleared firstly, then start over, if they re-appear they are the codes/problems to attack, codes DO NOT clear themselves even when the problem is fixed, someone has to clear them with a diagnostic reader.
A drowsapp states, it can be one of a dozen problems from battery charge, alternator, earth grounds, ABS Module, wheel sensors, wheel bearings, brakes etc, etc but unless you know exactly what and where it's a nightmare trying to guess. IMO unless you really know your way around D2's the best (and most expensive) place is a top quality indy LR garage or a main dealership (I can't believe I said the latter, I hate dealerships), don't take your LR into a 'do it all' garage and expect them to solve your problems, they can't or won't I'm afraid.
Old Feb 25, 2017 | 05:06 PM
  #25
Friday Night Disco's Avatar
Did you look at the date of drowsapp's post??
08-30-2011, 03:59 AM
Old Feb 26, 2017 | 03:37 PM
  #26
Duh, nope, I don't dare, it's old ain't it
Still, the same criteria applies eh
cammyr01
Jan 5, 2015 02:42 AM
iplayblues4u@comcast.net
Jan 6, 2010 08:43 AM
vmann7
Aug 29, 2009 06:47 PM
Disco TN
Dec 4, 2008 09:17 AM
bmayer01
Feb 10, 2008 08:12 PM
