4.6 engine swap for 4.0 in a D2
It's pretty much a direct swap. But I believe you need to reprogram the ECU or use the one from the 4.0 truck. You also lose some power because of the smaller displacement.
I've swapped 4.0 to 4.6 and back, more than once. No reprogramming. No issues as long as they are both SAI, or not, and it you go from an SAI setup to a non SAI youll need to swap the heads. If, like me, you didnt start with SAI you just have to plug the holes or swap the heads. Everything bolts right up.
The difference between my old 4.0 and a freshly rebuilt 4.6 is pretty stark, power wise.
