4.6L leak around air filter
Old Sep 26, 2023 | 02:18 PM
OleMissRbl's Avatar
Default 4.6L leak around air filter
I occasionally get a check engine light and Nanocom gives codes:
P0175 = ADDITIVE ADAPTIVE MIXTURECORRECTION TRA BANK 2 DRIVE CYCLE B
P1000 = ADDITIVE ADAPTIVE MIXTURE
CORRECTION TRA BANK 1 DRIVE CYCLE B
I borrowed a smoke machine, had a leak around the Intake Manifold Brake Servo Vacuum, replaced the o ring and red retainer clip, then had smoke coming out from around the air filter. It looks like the filter was sagging around the center, allowing air to escape the housing. The air filter was OEM LR027408, but it is black and most parts I see online are orange. Is this not the correct filter, or is there something else I should be doing to prevent leaks?
Old Sep 26, 2023 | 05:06 PM
Harvlr's Avatar
It looks correct to me. I’m pretty sure that a leak at the filter (upstream of the MAF) won’t throw a code. If it’s leaking on the downstream side of the filter you want to fix it though.
Old Sep 26, 2023 | 06:26 PM
matt3502's Avatar
It looks like the front part of the air filter ( bottom of picture) is not seated properly.
All of mine have always been orange:
https://www.roverparts.com/filters/a...ters/LR027408/
deadlast
Jun 29, 2022 10:30 AM
JoJo The Giraffe
Jan 28, 2019 07:53 AM
Lando
Oct 30, 2018 06:39 PM
Savannah Buzz
Jun 2, 2014 09:24 PM
Switzer
Nov 7, 2008 11:47 AM
