94 disco wont start
Old Oct 4, 2009 | 07:27 PM
Eurotrash's Avatar
Had the same problems with a 88 ck1500 and it was the secondary in the coil breaking down.
Old Oct 7, 2009 | 05:14 PM
lgduncan's Avatar
i put in a new coil, spark plugs, and spark plug wires. still no dice.... does a 94 discovery have a crankshaft positioning sensor?
Old Oct 7, 2009 | 05:16 PM
lgduncan's Avatar
sorry im new to this Land Rover forum.... the secondary coil.?.
Old Oct 7, 2009 | 06:10 PM
No a '94 does NOT have a crank sensor.
It has a distributor cap and rotor.
What have you done to the truck so far?
Checked for spark and replaced a coil but have you done anything else?
Old Oct 8, 2009 | 04:10 PM
lgduncan's Avatar
i tried all the test you told me to run... i took it to a garage and should find out tonight. i i was thinkin ckp.. guess not so i guess im thinking wiring or ignition switch...
Old Oct 8, 2009 | 08:54 PM
gcredlon's Avatar
I've had the same problem before and it turned out to be a crank shaft sensor. the ignition coil is also a good bet.
Old Oct 9, 2009 | 04:33 PM
lgduncan's Avatar
Default It Runs again
I took it in and got it back the next day. It was the rotor and distributor cap. I guess i shoulda looked closer at that... ny ways thanks alot Spike555
Old Oct 9, 2009 | 07:49 PM
Glad she is back on the road and running well again.
Thank you for posting what the final fix was.
Now when someone does a search maybe this will help them.
disconic
Jun 4, 2016 02:57 AM
gustav23
Dec 15, 2011 01:12 PM
armyeng
Mar 8, 2011 05:58 PM
jonsimon
Jan 29, 2007 01:55 PM
Drnknmnky13
Jul 5, 2006 06:54 PM
